Question about Asko W6221 Front Load Washer
Hi, I have an ASKO W6231 QUATTRO washer.However, the instruction book that came with it refers to a W6762, but we are in Australia, so who knows! It has a drop down outer door which I need to remove. Is that possible? It is purely for aesthetics and has nothing to do with the operation of the machine. Many thanks, Katherine
Check the outlet connection to the plumbing drain, could be blocked!
Posted on Jul 28, 2012
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
dauphine
  • 207 Answers
SOURCE: Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Posted on Apr 24, 2008
  • 351 Answers
SOURCE: Asko W660 Quattro Front Load
check the inlet valve solenoid there are three of them one might be o/c,also using to much soap can cause this or a coin stuck in the sump hose near the pump.the filter is in the valve but normally isnt the problem
Posted on Aug 28, 2008
Krazytech
  • 725 Answers
SOURCE: I have an asko wm200 washing machine. I have an F3
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
  • 351 Answers
SOURCE: Door latch switch failure
no you need to replace the door lock assy
Posted on Jun 16, 2010
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
How do you replace the pump cover with attached needle trap? On ASKO front loader washing machine W6231?
it usually unscrews anticlockwise, but check to make sure there isnt a retaining screw that needs removing first. they can be a bit on the tight side
May 02, 2014 | Asko W6021 Front Load Washer
I have an ASKO W6021 Quattro 1200 RPM. It does not complete the wash cycle. If I turn the know to rinse, it does rinse and completes. I tried it without any clothes in it and it does the same thing. I also...
Check that the cold water is turned on. The washing machine uses cold water to rinse, and if the cold water is not on, unit will end without completing cycle.
Mar 14, 2011 | Asko W6021 Front Load Washer
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
I have an asko quattro front loader washing machine it wont spin out properly leaving my clothes wringing wet can you help?
Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
Nov 01, 2010 | Asko Washing Machines
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
I would like to know what the buttons on the front of the machine are and also is it normal for these machines not to fill up all the way?
All wash machines have different button configurations , contact Asko or their agent in U.K. -- Maytag for an instruction book . Most modern machines are eco friendly and use only minimum amount of water , often filling just to the bottom of the door , but will vary according to drum size.
Nov 01, 2009 | Asko W6021 Front Load Washer
Asko W6221 Front Load Washer Logo
476 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
