Question about Cycling
My son peddle came off i guess his bolt that holds the peddle together got worn out is there a replace part for it....i juss need the screw that holds it together he has a smartcycle bike the 1st 1 they came out with
    Problem Solver:
  • 7 Answers
Most peddles have to simply be replaced when the bolt is damaged. There is no way to replace the part. They have new peddles for all kinds of bikes at your local bike shop.
Posted on Jan 12, 2011
Expand-It 40 volt locking collar T bolt stripped
http://www.ebay.co.uk/itm/Un-Used-Stihl-KM-Kombi-Power-Unit-Driveshaft-Clamp-Tommy-Screw-T-Bolt-and-Nut-/322089323385
Give these ones a try.. But NOTE; There is no need to tighten these up that tight.! There is no way that you should have to tighten them up enough to strip the thread.. its holding on an extension shaft together, its not having to hold the weight of a vehicle.
May 24, 2016 | Ryobi Garden
Rear brakes on 2011 kia sorento
Try a question rather than a statement.
I also give you the below from another answer:
Buy a Haynes or other manual. You need the pictures, dimensions, specifications and torques. DO NOT JURY RIG OR GUESS ON BRAKES. The fact that you have posted here for the entire world to see, if your brakes are not spot on and you hit someone, you will lose everything you hold dear in the subsequent lawsuit.
Jan 03, 2015 | Kia Cars & Trucks
Yamaha 4 hp outboard steering friction swivel screw does not work
That's a current problem.
OR the screw is rusted in place. So then use WD40 or eqivalent to free the screw.
Or the parts inside are worn. Remove the friction screw. Then, remove the 4 bolts holding the swivel cap. Remove the entire engine from the swivel to prevent it fall on the ground. Replace the worn parts.
Jan 18, 2014 | Clymer Marine Maintenance and Repair...
Clonking sound when im peddling backwards
please make this maintenance. God bless you
Depending on the amount of use, oiling your elliptical as much as once a month or once every 6 months can help prevent mechanical problems and avoidable repairs in the future.
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Aug 23, 2013 | Exercise & Fitness
My sons rt peddle broke how do i take it off to replace it
you need get an extractor engineering tool. Go to engineering shop and get one or ask them to do it. You will have to rill a hole trough and by using the extractor screw it out . BUT one pedal got right turn tread and the other left turn.
Other method it to weld some rod or bolt etc. on the bit what is inside and screw it out. Good luck
Jan 14, 2012 | Dynacraft Cycling
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Replaced frnt pads and calipers now brk peddle is sponge even after bleeding frnt brakes
You still have air in the system and must continue to bleed the system to get rid of it.Also you may need to pump the brake peddle for a couple of minutes to bring the brake pressure up again when the job is done.Do not continuously pump the brake peddle.Have a friend depress the brake peddle slowly as you loosen off the bleeder screw,have them push it to the floor and hold it ,tighten the bleeder screw.Foot off the peddle and repeat. Keep an eye on the fluid level in the master brake cylinder and add as needed. This can be a frustrating job and can take a lot longer than you might think.
Just relax, take your time,don't panic.Good luck
Nov 14, 2010 | 1998 Oldsmobile Cutlass
Cannot get bolt to hold charger cable to shycaddie body
I have the same thing, and just dug out the rubber ring where the thumb screw fits tight to the back of the unit. This has helped so far, but best shot is new cable, which I am sure I will have to get also.
Sep 13, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
I want to clean up drill inside. It si noisy probably because of the dust .
Juss take the screw unloose and replace it, if that don't work get another chuck.
Oct 11, 2008 | Panasonic EY6432GQKW Cordless Drill
Cycling Logo
127 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
