Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Have just bought a panasonic tv and every ten minutes an information notice comes on the screen about hdmi info etc how can I get rid of this?
  • Panasonic Master
  • 8,457 Answers
Go into ur tv menu.Goto OPTION.Go down to Program Display Title.Pick option No.Will have no more Info..ect. display anymore.
Posted on Nov 08, 2010
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
No picture in HDMI
After reading tips on this site I did a manual reboot of my cable box. Sure enough, that had been the problem. I'm going to keep a watch on it from now on; if it happens again, I'll call for a new DVR/cable box. Thanks for all the info on this site!
Jan 14, 2009 | Panasonic TH-46PZ80 46 in. HDTV-Ready...
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Joe
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
HI, just bought a digital hard drive recorder. All working well apart from the fact that EC1/ RGB is permenantly on display when the box is on, and showing on all recordeings. Panasonic Viera tv, how do I...
The only way out of this is to reset the TV back to 'shipping condition'. Go to Analogue Mode and then press Menu. In SETUP pick 'shipping condition' and ok your way through. Then switch off and back on again after a minute, and let it retune etc.
The annoying screen messages now disappear after a couple of seconds. Viola
Sep 27, 2008 | Televison & Video
Cant get picture
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Jan 09, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Panasonic pt-52lcx65 picture problem
Have a sears technician come over ,call them and set up an appointment, they are the best techs out there for tv issues, they will come out even if you did not buy the tv from them. Most of the Sears tv techs come from Philips which closed down their tech shop a while back. It sounds like you have dirty or faulty fans on your board. please advice.
Sep 10, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
