Question about Sprint Hitachi P300 Cellular Phone
My hitachi cmpas15ss 55 inch tv keeps making a clicking sound while switched on, have you any ideas what the problem is? Thanx
Hitachi 55" plasma: No picture, no sound
Perhaps the seller forgot to mention the basic power supply problems and who knows what else
Jun 12, 2013 | Hitachi 55HDS69 55 in. Plasma Television
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
The audio in Hitachi 62 in rear projection tv was intermittent and now it gone completely, I just replaced the Convergence chips because it had the 3D color separation ,i was able to fix that problem , now...
Model number 55VG825 IS NOT 62 INCH SET, IT IS 55 INCH DLP.
WHAT IS ACTUAL MODEL NUMBER OF YOUR TV?
I can give more information if you give me correct model number---if convergence is now working, it has nothing to do with sound unless you created the problem when you repaired it.
The more info you give me the better I can help you.
I am here to help people, I do this here for free.
SD TECH
Oct 31, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have been offered a 55 inch Hitachi Projection TV
Yes it is. A TV repair shop can replace the parts for less than $100.
Oct 22, 2009 | Televison & Video
Hitachi 55 inch plasma tv
what type of connector are you using fo your xbox? I think
Dec 13, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Tv problems
first i would check for any loose connections on the convergence ICs if not you may want to try to Replaced both convergence ICs (STK392-110)
Mar 23, 2008 | Hitachi 55UX58B 55" Rear Projection...
Picture not to full screen
Try connecting just the cable to the TV and bypass the cable box. If you get a full screen and the "ASPECT" button on the remote gives you full operation then either you need to change the output on the cable box to 16:9 output at 1080i resolution (because it sounds like the box is putting out a 4:3 screen size)or in your customer menus on the TV, I believe there is a "AUTO ASPECT" selection? If there is and it is activated then turn hat off. Having DVR won't effect the screen size. It just means the cable box has a hard drive built in to it.
Mar 12, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Sprint Hitachi P300 Cellular Phone Logo
114 people viewed this question
Top Sprint Cell Phones Experts
Dan Shibata
Dan Shibata
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
