Question about Ricoh Aficio CL7000 Laser Printer
My Ricoh CL7000 is saying add toner magenta. But there is plenty of magenta in the cartridge. I've added toner and cleaned out everywhere I can get to. Any suggestions?
  • 903 Answers
It could be a clog in the toner tube, but the most likely (and easiest to fix) problem is the magenta DV unit. Replace the magenta DV unit, turn the machine off and back on, and if it still says add magenta toner open and close the toner cover so that it can load toner, then your problem should be gone.
Posted on Mar 22, 2011
Life time of ricoh 3002c drums
Toner BK
Print Cartridge Black
Bla 841647
28,000prints/bottle*
Toner Y
Print Cartridge Yellow
841648
18,000prints/bottle
Toner M
Print Cartridge Magenta
841649
18,000prints/bottle
Toner C
Print Cartridge Cyan
841650
18,000prints/bottle
Feb 29, 2016 | Ricoh Office Equipment & Supplies
Magenta toner brother MFC9450C everywhere in printer
Take out the magenta cartridge and clean the nozzels and contact and reinsert it. if the issue persists get a new genuine brother magenta cartridge
Apr 20, 2012 | Brother MFC-9840CDW Laser Printer
My Ricoh CL7000 keeps asking to replace the yellow toner, which I have done and it goes through the motions of loading the toner then the error message comes back again - asking to replace the yellow...
The toner cartridges for the CL7000 have microchips embedded in them, so the machine knows if it's not a new cartridge. Was the cartridge you put in brand new? (And was it a genuine Ricoh cartridge?)
On those printers, the toner is pumped into a developer system and mixed with the developer before making the image. In the developer unit, the density is checked, so if it's not seeing the right mix there, one of three common problems could be causing this.
The more likely solution is to replace the yellow developer unit, which comes as a whole unit and just slides right in. That will reset your density levels and should correct the "load toner" error.
There is a spring and cushion mechanism that the toner cartridge sits on -- this mechanism can easily be popped out of place and cause problems loading the toner. Take out the yellow toner as well as one of the other colors, and see if the little black circular piece is sitting the same way for both colors. If not, just pop it back into place, using the second color as a guide.
The other likely possibility is that the yellow toner supply tube is clogged, but that doesn't happen very often. To test if it's clogged, take out the yellow toner cartridge and the yellow developer unit and turn the copier off. Use a vacuum to provide suction at one end of the tube (the toner end will be easier) and put your finger on the other end (the developer end) and see if you feel the vacuum's suction. If not, there is probably a clog somewhere in the line.
If there is no clog and you can feel the suction, you may have a bad toner supply motor.
As a side note, if you find the problem and fix it, you might still have to put a new yellow toner cartridge in to get the machine running because it will think the cartridge you already tried is empty.
Hope that helps!
Jun 11, 2010 | Ricoh Aficio 1035 Copier
Ricoh SP 8100DN will not load toner
The SP 8100 is a BW printer only, it doesn't take color toner.
Mar 23, 2010 | Ricoh SP 8100DN Aficio Laser Printer
Ricoh 4220 copier. I replaced toner cartridge and
I suggest removing the toner, and visually inspecting it, make sure the sealing tab has been removed, give it a really good shake, as the toner may have settled in storage. re-insert the cartridge making sure it goes in the right way.
If you can hear a slight 'clicking' noise it's adding toner and pumping it into the developer unit, some machines take 2 minutes, some take 6..
Failing that, lift the platen cover and do a few black copies, so you force the machine to add toner.
Goodluck.
Oct 16, 2009 | Ricoh FT3713 Copier
Ricoh CL7000
You NEED to REPLACE the black development unit with a BRAND NEW item......these things are chipped so it won't accept previously installed units.If the problem still exists try a new PCU (toner cartridge).
Apr 04, 2008 | Ricoh Aficio CL7000 Laser Printer
Add Toner
Your machine has got a toner pump on each of the colours wich transport the toner through pipes , these pipes get blocked and needs to be vacuumed out to clear the blockage .i got the service manuals if you need any further assistance
Nov 13, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh CL7000 Pink bands
Hi there you have the magenta drum cleaning fault. You will have to replace the Magenta PCU (Photo Conductor Unit) 99.5% sure
Thanks J
Nov 15, 2006 | Ricoh CL7000 DT2 Laser Printer
Ricoh Aficio CL7000 Laser Printer Logo
254 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
