Question about Fuji FinePix J10 Digital Camera
I make photos of my oil paintings - placing the painting on the floor and shooting down. The "auto focus" will not focus on some paintings and the photos are blurry. I have tried all settings tn "Manual" mode plus using the other shooting mode. Some paintings just will not be in focus! Any help will be most gratefully appreciated. Ken B.
    Brigadier General:
  • 11,967 Answers
I don't know how close you need to be to the paintings, but if it's close enough to need the "macro"setting, then you need to activate it for close focussing.
Posted on Nov 08, 2010
How to take pictures of paintings without the image appearing dark using auto focus
It sounds like your camera is under exposing a little. If you can, shoot in "raw" mode, and adjust in the software the camera manufacturer provides. Other things you can do: adjust the white balance for the lighting, override the camera's exposure to get more light, use flash, etc.
Oct 17, 2014 | Cameras
Oil from a reed diffuser spilled all down my bathroom wall on Benjamin Moore paint how can I remove the oil thT stained the painted wall
I would wipe it down with a degreaser like Simple Green, or paint thinner
The paint is ruin after cleaning it you will need to paint. You can prime the area with a oil base white primer in an spray can
Jul 23, 2014 | Tools & Hardware - Others
Paint will not dry after 14 days it is wet
you did not state what paint, on what surface, what is temperature and humidity.
paint usually do not dry if it is two pack and you used only part a (body of the paint) and did not add any part b (hardener). hardener allow chemical reaction to occur and creates then solid, this type of paint is often used on car bodies, boats, hard wearing flooring and similar surfaces. if this is the case, you need to strip and clean whole area, prepare it again, whip off with weak solution of appropriate solvent mixed with bit of hardener (about 1hardener to 25solvent by volume should be fine) rest it for 48hrs, fine abrade with 120 or 150 paper or screen and then paint again following instructions on the label. this usually involves two parts urethane based paints.
another - it can be oil paint - oil paints,, especially good quality (artist quality), based on linseed or cannabis oil, take up to few years to dry, they drying process is affected as well by humidity and temperature, if temperature drops below 10centigrade (50f) process of drying virtually stops, it will fully stop at about 2 to 4 centigrade (35f - 40f), humidity will greatly affect this process as well, very low humidity (below 10%) and very high humidity (above 80%) will hamper drying process, low by forming impenetrable surface skin and not allowing body of the paint to dry, high by preventing vapour pressure to evaporate.
please provide bit more info and then we may find better advice...
do not hesitate to ask extra - and do not forget to vote...
Apr 21, 2014 | Building Materials
I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
Paint problems
You have 2 options:
1. Get a quote from a paint shop, or maybe a local "backyard" spraypainter who could probably do it cheaper. Check your phonebook for spraypainters in your area.
2. Respray the roof and trunk yourself using color-match spray cans from your local auto warehouse. You will to use masking tape and newspaper to cover the windows, windscreen, trims etc that you DON'T want painted.
Sep 03, 2013 | Chevrolet Prizm Cars & Trucks
My autofocus on my canon 500d camera is not working properly. I find i have to switch to manual focus to take the pictures, even in all the atoumatic settings. I have only noticed this problem occurring in...
All auto focus cameras use contrast to focus so if you are attempting to focus on glass, chrome, blank sky, large body of water, painted wall, mirror, or any other low contrast subject the auto focus will fail. Another place auto focus will fail is when you are to close to your subject you my not be physically to close but have used the zoom to give a closer shot.
May 28, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
What soluntion is v best for my 2000 jeep grand cherokee lorado...i'm having problems with the low door panels as far dicoloring
a great fix for this problem is to take the Jeep to a ' Good ' auto paint shop and have them prep and paint the panels with a good quality anti-fade paint. make sure the paint shop warranties their work against chips and flaking. make sure they are going to use a good quality paint and primer.
this should only cost about 150.00 to 200.00 dollars at a good paint shop, with a turn around time of about 1 1/2 days.
now if you want to avoid that cost -- you can go down to your local auto parts store and buy a spray paint that works on plastics--- you will need to prep,primer and spray the panels following the instructions on the can -- the spray paint that they make these days come in many shades and hold up very well to the weather and sun,,just mask off the Jeep very well so you don't get over spray on the rest of the vehicle. make sure you keep one of the empty spray cans or a half full can around for future color match application. the cost of the spray paint can vary on quality and maker, usually around 8.00 to 16.00 dollars per can,, and primer and other supplies should run you around 30.00 more dollars. call around and shop around and ask lots of questions --- stop buy your local auto paint shop and ask them for a free estimate,, you might find a place that will do it even cheaper then I had quoted above (?).
good luck,
c...
Feb 02, 2011 | 2000 Jeep Grand Cherokee
How to re-paint scaped and scuffed car bumpers and fenders
In my experience, it's good to get paint that is matched to the original manufacturer's color from a place like NAPA auto parts.
Ask about the 'flex' agent as well, as many bumpers are made of plastic which will need it for a satisfactory result.
Then, get an air brush or detail paint gun and an air compressor (small) that can power it.
Sand the affected area with coarse down to fine sandpaper until relatively smooth.
Spray grey or red primer on the masked off area.
Fill the canister with paint and spray the scuffed and scraped bumpers or fenders.
You can paint small areas outside or in a large dust free garage, or preferably in a paint booth that has down draft ventilation.
Wear proper apparel for painting when you do this.
New paint can fill many cracks on several coats.
Oct 07, 2010 | 2004 Toyota RAV4
THE D100 REFUSED TO SHOOT THE PAINTING IN THE INSERTED IMAGE. CAMERA IN ALL OTHER RESPECTS WORKING FINE. TRIED ALL MODES.
When you say you tried full manual, I just wanted to check that you also switched to manual focus? The D100 has a switch on the right side of the lens, says M, S, C, for manual, single, or continuous focus? You need that in M with a painting like that, or to should truly diffuse subjects like clouds or fog.
The reason it works fine with only part of the painting in frame is that the camera can then identify and focus on the edge of the painting. It could also focus on any painting with linear or sharp detail. Autofocus is rather clever, but not clever enough!
If you had indeed set manual focus, then I admit I'm stumped. Full manual mode with manual focus never refuses to trigger the shutter on my D70; although it does often take pictures I don't understand at first. :) Good luck -- let us know what you find out, please!
Oct 19, 2007 | Nikon D100 Digital Camera
Fuji FinePix J10 Digital Camera Logo
78 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
