Question about JVC HD-52G886 52" Rear Projection HDTV
I need a lamp for a 52' JVC TV SKU:7302JHD how much and how long for shipment
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: jvc 52 inch hd-ila hdtv widescreen
you have a bad lamp or balast
Posted on Jan 22, 2008
  • 1039 Answers
SOURCE: power led and lamp/program led blink stimultaneously. even after unpluging and let tv cool, still no picture
Check lamp.
Posted on Apr 25, 2009
  • 8457 Answers
SOURCE: jvc 52" hd tv screen yellow
Have crack screen sign?Not fixable only require LCD changing,not buy able LCD screen only can buy it new from the tv compannies,but only sell as new tv only.
Posted on Jan 08, 2010
hardrocko
  • 1476 Answers
SOURCE: My 52 inch JVC tv keeps flashing a message saying
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem, how to repair the unit and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 01, 2010
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com
1. Purchase lamp TS-CL110UAA
2. Turn Off and unplugg set
3. Remove lamp cover located on the left side of TV
4. Remove and replace lamp
5. Reset lamp counter in menu for accurate hour information.
Jul 26, 2014 | JVC HD-52G786 52" Rear Projection HDTV
Tv tuns self off after a few min. lamp light is blinking.
The tv "LAMP" LED light indication flashing or ligting up?Yes,the tv projection lamp live are over.Tv require a new projection lamp.
Jan 08, 2011 | JVC HD-52Z575 52" Rear Projection...
My 52 inch JVC tv keeps flashing a message saying the lamp is going out and needs to be replaced. How do i do that? and where do i get a lamp from?
hardrocko
Jun 27, 2010 | JVC HD-52G786 52" Rear Projection HDTV
My jvc tv has a weird color to it and it says replace lamp lite blue is this something i can buy and put in myself?
Yes you can replace Lamp yourself! look on back of TV and write TV model number down. A lamp code can also be found on back of tv or located near Lamp DOOR.Easy replacement!
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
My tv says i need a lamp, what do i do
Usually lamp replacement procedure is written in user manual of TV and its an easy job.
Please confirm exact model number of your JVC TV to provide you user manual copy, if required along with lamp purchase info.
Thanks.
Dec 15, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
Lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Dec 21, 2007 | Televison & Video
Tv problem jvc hd56g786
your lamp bulb is probably finished so get a new lamp bulb they are easy to replace just look for a small panel on the side of you tv all you need is a flat head screw driver to open the panel and you should be able to pull out the lamp bulb
Oct 14, 2007 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G886 52" Rear Projection HDTV Logo
136 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
