Question about Samsung CLP-500 Laser Printer
Error I am getting an Error reading of DRUN 22701372 on my CLP500 printer. What's up Gene Lavine geneL@ncomo.net
    Guru:
  • 1,894 Answers
Do a hard reset and try to switch ON
Posted on Jun 16, 2008
Canonpc d340system error100
the machince is giving an error of e100, i have tried to change the drun together with rear unit but still gives the same error
Dec 21, 2013 | Canon PC-D340 All-In-One Laser Printer
Engine fuser low heat error
There is no other solution then to that problem with a CLP500 to bought a new/secondhand CLP510N and replaced the unit. Problem will be solved accordingly.
if you dont know how to replace, contact nearest Samsung Service Center. Good luck
do rate the solution if got help
Dec 06, 2010 | Samsung CLP-510 Laser Printer
I am out of ink on 3 colors, can i print with just black, the printer will not print
Probably not.
Replace the cartridges with Samsung factory new cartridges.
Do not waste your time and money with refilled cartridges or third party cartridges.
Don
Feb 19, 2010 | Samsung CLP-510 Laser Printer
141: fatal error OKI Printer
This can be caused by the transfer belt damage or the contact group damage. 141 is an error of Magenta ID up/down. Possible reason though - check the place next to the belt at the right hand side near the Magenta drum location. You'll see the terminals sitting in the housing with the spring. If the housing is fell off or the spring is missing - that can cause this error. Otherways you'll need to replace the transfer belt.
Jul 30, 2009 | OKI C7300 Led Printer
My hp laserjet 3030 keeps reading 79 error power on power off
79 errors are often fatal. Your only hope is to get it back to READY, then update the firmware before it reverts back to 79 ERROR. The other option is to replace the formatter, but it would be about the same cost to replace the whole machine.
Apr 07, 2009 | HP LaserJet 3030 All-In-One Printer
Samsung printer error
Time to buy a new transfer belt. samsungparts.com
Apr 29, 2008 | Samsung CLP-500N Laser Printer
Samsung CLP-500 error
Machine needs fuser replaced, normal user changable consumable, about 200 bucks in Oz
http://www.precisionroller.com/manufacturers/samsung-clp500.html
Nov 06, 2007 | Samsung CLP-500 Laser Printer
Engine Fuser Low Heat Error
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Aug 28, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-500 Laser Printer Logo
111 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
