Question about Grundig Roltronic Pro 8835 Electric Shaver
Will no longer run when pugged in - Grundig Roltronic Pro 8835 Electric Shaver
  • Grundig Master
  • 1,600 Answers
Batteries probably need replaced. You can buy replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you are not equipped to do this repair yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Nov 08, 2010
Hard to start when cold
code po450 refers to evaporative emission (EVAP) pressure sensor--circuit malfunction===causes --wiring---EVAP pressure sensor---ECM
replace the EVAP sensor
Feb 20, 2014 | 2002 Pontiac Grand Am
1990 ford F150 misfire pore running dies
Hey i recently bought a 1990 ford 5.0L 5 speed. Clutch safety switch was not working proper, bypassed the safety switch, truck was running rough but when you take the wire off of the small top post of the solenoid and apply it to the positive terminal of the solinoid it runs well. After tracing the wire i found that by applying that wire to the positive termina i get power to what i believe is the "run" wire in the TFI plug which is plugged into the distributor. it is the third wire from the right side of the plug when your looking at it with it unplugged facing yourself. Still trying to track down where this wire runs to but if i find out ill let you know sounds like we may have the same problem
Jun 01, 2012 | 1990 Ford F150
My 1997 accord idle after a complete and include plugs, all the belts. What could really be the problem
I'm guessing that after you installed new parts the engine won't idel correctly? While putting in the plugs you might have juggled the pug wires and have them connected in the wrong order if you id them one at a time this would make that more unlikly. Sometimes you get bad spark plugs ( the cheaper brands) and then you could drop them and close the gap or try to set the gap ( most modern spark plugs can't be set to a different gap without breakng the plug). The pug socket can fit poorly and shift and break the plug the resulting crark in the glas part of the plug will make fire poorly and missfire.,, Remove onr pug wire at a time with someone keeping the car running for you and remove the wires one at a time to see if the cyclinder is running. If you find two not running you might switch these two wires and see if that fixes it. if yu just find one the take that plug out and see whats happened as even a good mechainic can break a plug once in a while and you can buy bad ones too. while working on the car you might have knocked off a vacume hose off or just flexed one enough to split it. You might get someone to keep the car running as slow as possible and listen for leaking electril noise and vacume leaks.
May 06, 2011 | 1997 Honda Accord
Car takes a long time to start, like a few minutes. Runs fine once it finally starts. It gets closer the longer you crank. Changed pugs, fuel filter and some vacuum/pcv pieces, No difference.
FUEL PUMP GETTING BAD THE CHECK VALVE LETTING ALL FUEL DRAIN BACK TO FUEL TANK.HAVE VECHICLE SCAN FOR CRANKSHAFT SENSOR FAULTS. CAMSHAFT SENSOR FAULTS.
Dec 22, 2010 | 2002 Audi A4
1999 lincoln town car firing is orange and will not start?
Not sure what you mean by firing orange. Flame out the tailpipe? Spark at a pug wire?.. If it has spark then add fuel and see if it starts ( even if breifly) If it does your ging after fuel related problems. Crash fuel cutoff switch needs reset, fuel pump or fuel pump relay or pug bad ( rusted ) Blown fuses (pump drawing too much power) ( Bad pump). Timing chain, ( or chains ) 4.6 can throw ting off and the mileage and adbuse needs to be high for this to happen. Spark can be weak but if you have it it should still run just give problems.
Aug 08, 2010 | 1999 Lincoln Town Car
My speedometer just got stuck at 60 on wont go back down
And you haven't ran out of gas yet,,,,,, just kidding. Disconnect the speed sensor pug at the transmission. And start the car. If the speedo is still showing 60, you may have a bad gauge, as you are no longer sending a message from the transmission.
Feb 02, 2010 | 2004 Chevrolet Impala
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Weed eater runs slower
Your air filter may be plugged, your pug may be fouled, or your carb may be gummed up.
Sep 10, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
INTEX IT-305WC usb camera not plugged in
my INTEX IT-305WC usb camera is pugged in but whenever i run the setup for the driver i downloaded it says please plug-in device
Aug 27, 2009 | Computers & Internet
Grundig Roltronic Pro 8835 Electric Shaver Logo
494 people viewed this question
Top Grundig Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ray gallant
Ross Keen
Are you a Grundig Health and Beauty Expert? Answer questions, earn points and help others
