My Technics sa-ch750 amp cuts out when the volume goes over apr. 26db. I have a t1.25a 250v fuse on theboard near the power which is what it says is required on the board. Not sure if i need a specific type of fuse. Any ideas?
SparkGap
  • 363 Answers
SOURCE: remote control code
You need to let us know the make and exact model number of the universal remote. All universal remotes do not use the same codes. We'll try to help you control your technics sa-gx100 upon your reply.
Posted on Sep 29, 2007
SOURCE: technics sa-ex700
Hi,I have the same receiver...and what you mean by "the two stk".....i have the operation manual whith the specs....
Posted on May 24, 2008
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Have you checked to see if your fan is still working.....I am having the same issue but I think it's my fan b/c it was doing this when I first got it and for the 1st couple of years.
Posted on Jul 31, 2009
  • 11 Answers
SOURCE: i want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Posted on Aug 04, 2010
Hi I have SA-EH550 technics HI-fi music system. Start my system low volume no any problems but I adjust volume high after some time system go stop and show error code f61 Please give solutions. Thanks..
On some systems F61 is to do with the fan not working properly, sometimes blocked with dust. On others it's a power amplifier failure. Yours does sound like a power amp problem, but both should be checked.
Sep 26, 2018 | Technics Audio Players & Recorders
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
I am playing Cd's and have a pair of Definitive Technology- Model BP-10 tower speakers connected to my Technics SA-DX1040 5.1 Channels Receiver and while the music is playing, all of a sudden the music...
There are 2 major possibilities and since you didn't say if the sound comes back here's the general split.
1. The power amp section could be having problems and/or protection circuits are kicking in. In this case repair of the amp will be needed.
2. There is a bad connection somewhere making the audio path go bad. In this case a good can of contact cleaner applied to all switches and controls may help. If not, the bad connection may be internal. If tapping (or rapping) on the unit makes it come back, there's probably a bad internal connection.
If letting the unit cool down brings back the sound, its the power amp section.
Dec 27, 2010 | Technics SA-DX1040 Receiver
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
When i turn up the amp the 'current drive' cuts
Check all your wiring for short circuits, check your speaker coils are not shorted either - if you cant do this try any other pair of speakers on the system.
check the main capacitors in the power supply, check the internal fuses, and change the wall plug fuse - check all the large capacitors for closed/short circuit or cracked solder joints, resolder anything suspicious looking. the fuse could be **nearly** blown, and bend apart when it gets warm, change it to be sure... hope this helps.
Jan 25, 2010 | Technics Audio Players & Recorders
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Feb 18, 2009 | Technics SA-DX950 Receiver
Cooling solution for technics volume controlled fan
fit a case fan from an old p.c to the 12volt rail or ex ternal power supply put the amp at the top of the pile
Jun 29, 2008 | Technics SA-DX940
Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Aug 06, 2007 | Technics SA-AX540 Receiver
146 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
