Question about Siemens Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Posted on Dec 18, 2010
  • theredrage4 Dec 18, 2010
    I should mention that was 3 beeps, 5 beeps means the lid is not closing properly.
  • wilson102 Jul 04, 2011
    how do u fix the lid? is there a sensor switch?
Is there a reset button on a Simpson Eziset 750?
no
what is the problem
if it is on pause press the start button and hold for a few seconds
May 14, 2017 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Simpson eziset 605 wont take in hot water
Hot valve in washing machine required. Part is between $25 & $60 STEP 1: unplug machine STEP 2: undo the 3 Phillips screws on top of machine the fold top console forward STEP 3: Undo hot tap,disconnect 2 wires running to hot valve,remove valve,fit new valve. STEP 4: Refit top console. DONE
Jun 17, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
I have a Simpson Eziset 550 washing machine and it does not fill with water at the start of a wash - instead it will start to fill then stop and all three lights on the water temp gauge light up and start...
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Nov 01, 2010 | Washing Machines
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Sep 20, 2008 | Washing Machines
Washing Machines Logo
949 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
