Question about Senco SLS20-K Stapler, Sequential
The driver does not go back in the cylander - Senco SLS20-K Stapler, Sequential
  • 885 Answers
You have worn or broken o-rings in the head of the gun. I can't find a referance to an SLS20K Senco stapler, they do make an SLS20 and SLS20XP and each takes a Senco YK0372 rebuild kit.
Posted on Nov 08, 2010
Can you put a 5.4l cylender head on a 4.6l motor with a 4.6 cylander head
Obviously if you have the bad head off, you can compare the two. The extra .8 could be made up in piston stroke. So if the holes all line up, I would go for it as long as the two match in all aspects.
Aug 09, 2014 | 2005 Ford F-150 SuperCab
Water in all cylanders
Sounds familiar. If the engine oil is too full, oil will splash into the spark plug openings. Then, condensation will sit on the oil shorting the plugs. Be sure not to overfill. Also, the valve cover gasket has an inside seal. Once again, oil will partly fill the spark plug hole if the gasket is bad. There is a large hole in back of the valve cover leading right to the plugs. Be careful not to rinse the engine. Gaskets seal the plugs but water can sit on the plug openings.
Dec 26, 2013 | 2000 Kia Sportage
Spark plug order for 1997 honda accord lx and distributor cap
i you have a 4 cylander it is 1,3,4,2.
if you have a 6 cylander it is142536.
May 01, 2010 | 1997 Honda Accord
#4 cylander is misfiriing where is the # 4 cylander located on a 2002 Ford escape 6cyl. 4x4
Middle cylinder on firewall side of engine. Front is 1-3-5, firewall side is 2-4-6 from front of engine.
Apr 25, 2010 | 2001 Ford Escape
I NEED TO POP THE TRUNK AS THE KEY CYLANDER IS HANGING INSIDE THE TRUNK
You can crowl thou the back set area and remove the lach cach it will take a 10mm socket and rachet. then you can reset the cylander.
Jul 14, 2009 | Honda Civic Coupe
Rear exaust manafold won't move and line up with cylander head.
Are there studs or bolts on the front cylinder head? If there are bolts then secure the rear manifold first.Or replace the rear studs with bolts.
May 16, 2009 | 1999 Ford Taurus
Problem with brakes
the brake booster has a rubber diaphragm in it that sometimes goes out and causes that problem
Apr 21, 2009 | Dodge Ram 3500 Cars & Trucks
My VMAX100UWH elite screen will not go back up. However I can hear the motor running when I press the up button. Is there a fix for it or does it sound like the motor is blown
I have the same problem. I removed the motor, at the end of the cylander that holds the screen on the motor side, there is a black cap that connects to the motor and makes the cylander turn. Mine was broken, hence the reason for the screen not retracting back up even though the motor still works. I contacted EliteScreens but they said they no longer carry parts for this screen. Now I'm trying to find the part online.
Jan 19, 2009 | Elitescreens VMAX100UWH 101" 16:9...
1994 Corsica
The coils should be numbered, and the cylinders will be numbered from the front of the engine back (the front being where the water pump is, generally the left or passenger side of the car). If it's the four cylinder it's easy, 1-4 straight back, and if it's the six, then 1-6 starting with the front left cylinder being the fisrt and criss crossing front right the second, second on the left being the third and so on. If you have anymore questions, please get back to me quickly, I'm getting ready to go out for the evening.
Jul 15, 2008 | 1994 Chevrolet Corsica
Senco SLS20-K Stapler, Sequential Logo
245 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
Matt Olenzek
Matt Olenzek
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
