Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Correct placement of small rubber back-flow valve into keg coupler....
I have a Danby DKC 445 BL. After disassembling & cleaning the keg coupler, I thought I reassembled it correctly, but obviously not because all I get now is the sound of air when I pull the handle and foam... I think I have reinstalled the little rubber (what I call the) check valve / back flow valve. I can't find a detailed assembly chart online. Can you help? Many thanks, Marshall (marshallmaher@aol.com)
SOURCE: Danby Keg Cooler foam problem
Set co psi 8to10 lbs
Posted on Aug 03, 2007
Master_Tech
  • 770 Answers
SOURCE: Too much foam
well you are right the CO2 is causing the foam you may need to replace the regulator on the tank it is most likely bypassing the bellows inside...as a temp fix you can shut down the co2 and bleed off the air then just crack open the tank to (hand) regulate the flow ..
Posted on Feb 16, 2008
SOURCE: foamy beer
Keg's are normally pressurized at 13 psi. If you only set yours at 8 psi then you are going to cause problems. You should always start at least the same psi that the keg is set to. If you can talk to the keg company as they all differ some. Common problem is to lower the psi which will cause foam until you reach about 1/2 full or a little less then you should get less foam but your beer will become very flat. Too much pressure is usually better than too little, even with too much pressure you'll see the beer come out fine but will start to foam when hitting the glass/pitcher. Also note that the coupler's that Danby use are very cheap, check the CO2 vale (between CO2 line and coupler) to see if there are any cracks or anything.
Posted on Apr 15, 2009
SOURCE: i have a danby kegerator that is spitting foam new
Turn off the co2 for now. Turn it on when you need it, but start at a much lower pressure like 2-4 psi. Adjust pressure as needed.
Posted on Apr 21, 2009
  • 207 Answers
SOURCE: i have a danby kegerator and i just tap the keg
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Posted on Feb 24, 2010
Beer system won't pour properly
Most of the time this reason is the beer temp and co2 is not right. first you dont go buy box temp but need to get beer temp. first make sure you have a calibrated thermometer. check your thermometer by mixing up a glass of ice and water let it stand a couple Min to achieve 32deg. put thermometer in water let stand 2 min to make sure it reads 32 deg. now draw a couple of glasses of beer in the same cup pour each in a pitcher. now draw a 3rd glass of beer in the same glass put the thermometer in it you wont the beer at 38 deg if to cold turn your box thermostat up or if to hot turn your box thermostat down to achieve a 38 deg beer. now it is time to check the CO2 pressure, you wont it at 12 psi. first drink a couple glasses with your friends this will let your keg pressure equalize. Now it is time to do a test poor. If the faucet gives a spurt of foam when you open it or the beer runs foamy-clear-foamy-clear than the pressure is too low, bump the pressure up 2 LB and let the pressure equalize a few min. If the beer runs to fast, turn off the co2 at the shut off where the tubing connects to the regulator (Always turn off the shut off when adjusting the regulator). Release some pressure from the keg by pulling the pressure relief valve on the keg coupler. Drop the co2 pressure 2 lbs. Turn the co2 line back on and let the pressure equalize. Often you can tell if the pressure is too low by looking at the beer line at where it connects at the keg coupler. If you see bubbles rising up the beer line from the coupler the pressure is to low or the seal on the keg or coupler is bad. Over many years of trouble shooting 3/16" bore shanks and fittings can cause a burst effect releasing carbonation from the liquid. The beer flow looks good but you end up with a glass half full of beer and half foam. For this reason 1/4" bore shanks and fittings should always used on the liquid side.
Mar 04, 2014 | Scotsman Kitchen Appliances - Others
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Flow from faucet is impeded
This happens a lot when you clean the unit and you but the little tiny ball back into the tap incorrectly. Check your ball for proper placement within the tap.
Jun 13, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
No flow from keg
when was the beer hoe last cleaned? also have you checked the regulator on the tank......disconnect all hoses, and make sure all cloggs are cleared
Jan 01, 2009 | Danby DKC645BLS Compact Beverage Cooler
Foamy beer
Sep 27, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Keg coupler
Check YouTube for something similar.
Oct 11, 2017 | Danby DKC646BLS Full Size / Pony Beer Keg...
Installing the lines to the keg
check to see weather or not a pump is needed to pressurize your keg.
Jan 26, 2008 | Danby DKC645BLS Compact Beverage Cooler
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
If you are getting foam then finally poors fine you have a temperature problem. If you are getting constant foam then you are probably looking at a pressure problem. First of all make sure that you let your keg sit for at least 4 hours and get down to 38 degrees before you tap the keg. Also ensure that your pressure is set to at least what the pressure is in the keg (generally 13 psi). If you can, try to ask the beer manufactures (if you use a microbrewery) what pressure to set it at. One brew master told me to start at 15 psi and adjust from there.
If you still get foam and you can guarantee that the temperature is correct then you are getting some agitation from something else. Double check all your washers and even check your stop valve on the CO2 line to the coupler. Sometimes the lines are not the correct length or even the correct diameter, when the beer is forced through the line if it starts out thin and then expands or vice versa that gives beer a chance to get agitated and cause foam.
Finally the equipment that is used on these systems are generally not that great. I had a Danby Chill'n Tap and replaced the coupler and the tap and all the lines and that solved my issues, even though my problem was probably a cracked valve for the < $80 it cost me to replace everything it wasn't worth my time to figure out exactly what was wrong with it.
Jul 26, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
220 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Oloyede Monsuru
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
