Question about Dewalt Hammer Drill Sds2x18 V Batt 5 Sds Bits Cordless
Hi could you tell if any outher battery charge will work on my macallister sds drill as my charge is brocken can you help
Have a look at WORX DRILLS the 14.4v battery and charger are exactly the same as my macallister drill and i have been using it for a few months wihtout problems
Posted on Oct 08, 2013
  • Dewalt Master
  • 7,733 Answers
I have a dewalt 24 volt sds drill when attach the fully charged battery to the body nothing happens when i remove the battery from the body it starts to smoke
So what is your question. It sounds like you have a bad battery so try it on another tool. If it works then the drill is not working or assembled properly if the same thing happens then you have ruled put the drill and there is a proplem with the battery
Mar 03, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Cordless sds leaving grease on sds bits
There is supposed to be grease on the chuck end of SDS+ and SDS Max bits. Actually, you should put a little lightweight grease on the end of the bit every time you put one in your drill. If you, or noone who has ever used the drill, have ever done this, it is possible internal grease is leaking out of the drill and it should not. There are seals to prevent internal grease from getting out of the transmission and striker mechanisms. If you are loosing internal grease, these seals should be checked.
Feb 14, 2013 | Dewalt DW005K Rotary Hammer
Bosh 24v sds battery problems
Have you tried charging and discharging the battery a few times, sometimes that helps build up the charge.
May 31, 2012 | Drills
How sds drill differ from ordinary rotatary drill .what are main basic feature of sds hammer drill
The difference is the working action. SDS drills use a corrugated cams running against each other.
May 30, 2012 | Drills
Red light comes on after a couple of seconds and the drill stops working
Hi did u get this fixed my one does the same battery say it's full but red light comes on drill stops cheers
Apr 03, 2012 | Metabo 600190520 KHA24 24V Cordless...
Sd rotary hammer drill 110 volts bit brocken in chuck
Put some WD40 into chuck and wait a few minutes. Open the chuck as you would do when normally removing the drill while at the same smartly tapping the back of the drill.Alternatively try to grip the broken drill bit with a long nose pliers to extract it. A strong magnet might also pull the bit out.
Nov 08, 2010 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Drill running slow
Is the battery fully charged? Is the slector switch on high?
Sep 15, 2009 | Dewalt Dc212 18 Volt Sds Plus Rotary...
24v sds.no lights on charger but making humming sound.all 3 batteries not charging.any ideas?
If it is out of warranty open it up and check the fuse inside. This has happened to me several times with several brands, and it has always been the fuse. They are usually replaceable at Radio Shack or the Auto Parts Store.
Hope this helps!
Jim
Aug 05, 2009 | Ryobi Multi-Volt Battery Charger
Dewalt Hammer Drill Sds2x18 V Batt 5 Sds Bits Cordless Logo
210 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
