Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My pull start cord won't retract. How do I fix it
    Brigadier General:
  • 4,088 Answers
Remove the starter assembly from the engine and pull the cord out--it should have spring resistance to pulling. If nothing, the rewind spring may be broken, or it may have pulled loose from one of the attachment points. Remove the cord from the pull handle and unwind it from the spool if it isn't already pulled out. Remove the spool from the frame to expose the spring--check the ends for breakage and the attachment points for damage (one will be on the under side of the spool). Repair or replace any damaged components and assemble the spring into the attachments. Wind the spool/spring about 2-turns CW, then wedge it to prevent unwinding. Fit the cord back into the spool and wind it CW until the cord has about 8" or so to feed out through the cord port. Fit the cord end back into the handle, tie an overhand knot, and push the knot into the handle bore. Remove the spool wedge and try pulling the cord several times to make sure it goes out and back smoothly. Return the starter to the engine and attempt starting. Hope this helps!
Posted on Nov 09, 2010
How do u fix a loose starter cord people?
Hi Rick:
Most starter cords rely on a recoil spring to make them retract.
Sometimes when the cord is replaced it is longer than the original so just needs to be shortened. Pull the cord all the way out and if you have way more than you use for a pull start, then shortening it is a fast fix.
To do that, pull out the cord a couple of feet. flip a slip knot in it to keep it from retracting, then take the start handle apart and shorten the cord about 6 inches. Should work fine.
If the cord is talready too short to make it shorter, you'll need to put another wind on the spring.
Reply as a COMMENT to this post af you need coaching through that.
Hint. Don't dismantle the spring assembly so it can get out. They are related to rattlesnakes.
Cheers.
Feb 08, 2016 | Garden
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
Pull cord won't retract
Hi Susan. It sounds like the spring has either snapped or become un attached. It's going to be a two person job to re do it. It may be worth while going to a scrap metal merchant and getting the recoil starter of an old mower.
Jul 26, 2013 | Poulan Garden
Starting cord won't retract
if its brand new take it back tell them the retraction spring is broken and fix it
Jul 25, 2013 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
I have a troybilt tb-144 4 stroke mini tiller. The pull cord, pulls and retracts as it should, but is not engaging the engine when pulled...
remove the top cover. look inside while pulling rope briskly, you should see two dogs fly out and retract when the cord reaches its end. if not, check for dirt in the system and clean out. if no dogs, you will have to remove the system from the housing, be careful of the spring. check for any broken drive parts. also check flywheel cup for damage where the dogs come into contact with it.
Apr 15, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
2,418 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
