When i turn it on it shuts its self off in seconds of me turning it on
    President:
  • 2,777 Answers
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will want to contact a local TV repair person in your area if you are sure this is out of warranty, more on that in a bit here. This is actually the most common problem with this type of TV, I see it every day, it just happens - sometimes with new TVs and sometimes it takes many years for it to happen.
If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
If you want to attempt the repair yourself please let me know and I will get you the part number and a place you can purchase it from for what you need.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Posted on Nov 08, 2010
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
Oven Stuck on Self-Clean/Locked cannot undo
you can press the clear off button for 3-5 seconds this should turn off the oven. if not turn off the circuit breaker for a few minutes then turn it back on and hit the clear off button again
Feb 27, 2010 | Ovens
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
