Question about Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB Hard Drive
What is the master code to unlock a fujitsu hard drive 80 gig modle number mhv2080at
  • Anonymous Mar 30, 2014
    Is their a master code to unlock my hard drive
BR549
Posted on Feb 17, 2011
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
I have purchased Fujitsu MHV2080AT. It says new hardware found and it is ready to use but I dont see any drive on mycomputer. But if I see in mange it show the "VUZIVSW_HV228AV RL2 2 USB device"...
Right click MyComputer and select Manage. Look for Storage on the right and select Disk Management. Find your drive and format the partition by right clicking it and selecting Format. Use NTSF, default allocation size then give the drive a letter or name. After that it should show up in MyComputer.
May 04, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Good day... I have a Fujitsu Problem with the Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB Hard Drive Good day... I have a Fujitsu MHV2080AT USB Device (External USB Hard drive). 80 GB. I lend it to a...
starting with your last question first, our advice is free but you can choose to pay someone for their professional advice if you wish.
from vthe symptoms you explain, it sounds like the the drive is just about dead, continual clicking usually indicates some sort of physical damage to the drive itself.
if the drive fails completely, data recovery would be quite expensive in these instances so if possible you should get another external drive and transfer your data before the inevitable happens.
Apr 18, 2011 | Computers & Internet
Good day... I have a Fujitsu MHV2080AT USB Device (External USB Hard drive). 80 GB. I lend it to a colleague at work before I leave for my annual leave (since it has some info he'll need during my...
When you power up the computer press F8 key then enter in safe mode note down the drive letter like f: then go to command prompt and type "chkdsk f:" without "" where F: assume as your drive letter. then follow below. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Apr 14, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
My hdd is not working. which hdd model can i buy instead of mhv2080at?
Bro i recommend Maxtor DiamondMax Plus 9 80 GB (6Y080M0)
Hard Disk specifications:
1.0. SATA cable hard disk.
1.1. include 80 GB model for test series.
2. includes 8MB of cache.
3. with fluid dynamic bearings it mean that it will runs nice and quiet and can do fast transfer of informations.
May 28, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
What kind of enclosure and cable do I need to make my drive exter
This drive is an IDE/ATA hard drive.
To use this as an external hard drive, I suggest you purchase an USB hard drive adapter case (with an USB cable) and install the hard drive into this case.
When you plug this adapter into the USB port of a computer, the computer will see this as an external hard drive.
Mar 22, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
HOW DO I CONNECT THIS DRIVE TO MY DESKTOP PC ? WHAT TYPE OF ADAPTER DO I NEED?
The adapter has both interfaces on it...that is, it will plug into an EIDE interface or the SATA interface. The other end is a USB connection for plugging in to the computer, this way the computer treats the drive as an external. They sell for around 20 bucks.
Oct 09, 2009 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB Hard Drive Logo
389 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
