Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Static and low reduced volume on both treble and bass audio. Satellite connections checked, reset TV at the control box and unplugged and replubbed. The set is three years old and is Sharp LC3707U
  • Sharp Master
  • 6,993 Answers
its likely that your TV's sound chip/IC is defective and needs to be replaced for your sound to be sharp and effective again.
If you know about electronic repairs, open up the TV, remove the defective sound chip, take it to any electronics accessories store within your vicinity, and use it to get the correct replacement and all should be well.
But if you don't have any idea about electronic repairs, take it to the nearest repairman withing your vicinity to fix the sound problem for you.
Good luck.
Posted on Nov 08, 2010
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
I want to reduce the bass on my logitech X-210 speakers.
Go to speaker icon bottom right corner of screen.
Right click and choose audio options
You should have sliders for bass,treble,volume etc
Jun 22, 2011 | Logitech X210 2 Speakers
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
Could you please explain the differences between the different equalizer settings as far as bass and treble
The bass setting can be set to either boost or reduce the bass (low frrequencies. At midpoint it is considered "flat", that is it neither boostts or reduces the low frequencies.
The treble acts the same idea BUT for the high frequencies.
Both these are essentially electronic filtering techniques to seperate the highs and lows.
Dec 31, 2009 | Emerson MS3100 3-Disc CD Changer
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Any info on Altec Lansing Satellite 31 set up?
Hi, I have these. Always unplug the Sub before changing the wiring around.
You should have a dual cable. Plug one end into the Sub's Audio In and DC Out (the one that looks like a power plug goes in DC Out, the one that looks like a headphone goes in Audio In). The other end of the dual cable goes to the Satellite that has the volume control. Plug into DC and Sub. Plug a cable with headphone plugs on each end into the SPKR jack on each Satellite. Plug another cable with headphone plugs into either Input 1 or Input 2. The other end goes to your computer's audio out. I don't have the original of these two cables so I can't tell you what they look like. If one is longer or thicker it should be the one to go between the speakers. Set the level control on the Sub about 1/4 up. Plug the Sub in and play some music. You can adjust the Sub level and the Bass and Treble to your liking. I have my Bass & Treble straight up, Sub at 1/4. You can use one of the inputs for your computer and the other input for another device like an iPod without having to unplug things.
Jul 17, 2008 | Audio Players & Recorders
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
