Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
I have a SONY KF-42WE610. When I turn it on a red light flashes 3 times under the power/standby. I was told that 3 lights means that there is a problem on the G or G1 board. Is that a board that I can replace?.
  • 1 more comment
  • mrs_tharp Nov 08, 2010
    Thank you for the help. Well...my husband stuck a pair of pliers to hold the button down and it stopped blinking 3 times. NOW it blinks 5 times. The door is a little warped so maybe that is causing the problem. I can get a new door, but what does the 5 red blinks mean??
    A side note...i put the door back on and tightend it up. It isn't blinking 3 times even with the door on now. When I turn it on it blinks green for a while and makes a static type sound like its trying to start. Then it stops and keeps blinking green for a while and makes the sound again. Then it blinks green a couple more times and starts blinking red 5 times.
  • mrs_tharp Nov 09, 2010
    Thank you very much for the help. I was wondering if you happend to know off hand what the part number is for a ballast unit? I don't seem to be having any luck finding one online. If not I guess my husband will just have to take it apart and hope there's a number on it. lol Thank you.
    Genius:
  • 1,030 Answers
According to service manual 3m blinks indicate the lamp door cover is loose or open
Posted on Nov 08, 2010
Testimonial: "Gave me some info that nobody else was giving me anywhere else. Thanks!"
  • 1 more comment
    Thank you for the help. Well, my husband decided to stick a pair of pliers in the slot to hold the button down for the door. Now it blinks 5 times. The door is a little warped and that may be causing the problem. I can get a new one. My question now is, what does 5 blinks mean???
  • Willie Howell Nov 09, 2010
    5 blinks is a lamp driver error.... now this can mean a couple of things..first remove the lamp and check to see if its not blown....ussally when they go bad they blow and perhaps overheating caused door to warp. a lamp can be bad and still not look bad. this error occurs when the lamp fails to light. worst case i see is a faulty what is called a ballast unit which provides the high voltage to the lamp much like a florescent light does. and those can be replaced. but check the bulb first.. as always let me know how it goes
  • FHBSMF Dec 13, 2010
    Thank you for the information, the door was warped and not making contact with the switch. The TV is working great! Thanks again.
    Sam S
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
I have a sony KF-42WE610. When I go to power it
More than likely it is the G1 board or Thermal Fuse. I replace the thermal fuse and it is still giving me the 6 blinking red lights. Thermal fuse is $40 and cheapest G1 board I have found on-line is $120. I am about to pull the trigger on the G1 board and give it a shot.
Mar 01, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Sony KF-60WE610, green light flashes few times and return to red, what could be the problem TV only five years old
Your lamp (back lighting) is burnt out and need replacement. The instructions are in your manual
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Dec 09, 2008 | Sony XL-2100U Projector Lamp for...
KF-42WE610
This sounds like an issue with the optical block assembly. Sony had a problem with this part in a lot of the KF-series television.
They extended the warranty of optical blocks in the KF-42WE620, which doesn't help you but from what your saying this sounds like the issue.
Jul 28, 2008 | Sony XL-2100U Projector Lamp for...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
KF 42WE610 turns on for two seconds, then goes black
no, had the same problem. Its the lamp ballast also called the lamp power block. It supplies power to the lamp, any how some repair shop wanted $450 to fix it, so i ordered the part from sony, part #146879816 ($116.25), trust me this is the part I double checked with many different places. Any how fixed it my self took about 15 minutes, just take the back cover off and the part is right there just kind of follow the screws and the 3 wires, super easy job, I suggest you replace the bulb at the same time, dont by a cheap bulb just get it from sony
Nov 06, 2007 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
688 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
