Question about Honeywell Heating & Cooling
We purchased our home two weeks ago and have a problem with the central AC. It will not turn on. When we did get it to turn on it ran for 15 seconds and caused the circuit breaker to turn off. Is there a quick solution or do I need to have someone come in and repair it? This is a Honeywell heating and cooling unit. We changed the batteries in the wall control panel and that did not help. We live in West Milford. What should we do? Thanks, Mary
  • 230 Answers
It sounds like the compressor is pulling high amps causing the tripped breaker. It could be caused by a weak compressor. This can sometimes be handled with a super start capacitor. This can reduce the amount of start up amperage. I suggest that a licensed technician do this for you because it is relatively dangerous and technical. The worst case scenario is that the compressor itself is bad and must be changed. This can be a very expensive repair.
Posted on Jun 16, 2008
We just purchase home weeks ago.I opened the bosce dish washer found it had a musty order.The following day i ran a dish washer agent,which didn't work.clean the washers filter noticed green algee.
Put two cups of bleach in it and run it on a long and hot wash. The best way to stop the odor is to use it regularly and leave the door open for 15 minutes after you use it so it can dry out a bit. There will always be some water in the bottom in the pump.
Sep 23, 2017 | Cars & Trucks
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Car will not start
check for spark and fuel its one of them
Sep 18, 2012 | Audi A6 Cars & Trucks
HELP!!!!!!!!! Gmc envoy 2003 A few weeks ago my abs brake light
Are you not getting a check engine light ? Take your suv to auto zone and get them to check it for codes and post the codes I will check back later to see what codes you posted they will help in finding the problem. Thank you
Oct 30, 2017 | 2003 GMC Envoy
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
My 775t gets hung up at 23% when calculating a simple route
look for a small hole in bottom of unit. insert a small pin or paperclip and hold down for 15 seconds. try turning on again. Are you sure you have the correct set of maps for europe? you may need to manually switch to the correct map set as the unit may not switch automaticlly.
Sep 13, 2009 | Garmin GPS
1992 BMW 320I starting issues
It is possible that you have the two small wires reversed or one is touching battery lead connection.
May 09, 2009 | 1997 BMW 318
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
