Question about Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television
I have a sony ke-32 ts2 plasma tv. I recently replced the tuner board. It worked fine once. the next time i turned it on the screen was red. now ech time i turn it on the screen goes frob black to light grey, but nothing else ill work,canot change channel, or av input etc, any ideas?
  • tonyskinner2 Nov 16, 2010
    HI THERE
    WELL i HAVE TRIED PUTTING OLD BIT BACK IN TO NO AVAIL. THE PROBLEM STILL REMAINS: HAVING CHANGED THE TUNER BOARD ON MY SONY KE-32TS2 PASMA TV IT WORKED FINE ONCE. THE NEXT TIME IT WAS TURNED ON THE SCREEN WAS RED ON THE AV CHANNEL. NOW ALL I GET IS WHEN I TURN IT ON THE SCREEN GOES FROM BLACK TO LIGHT GREY, THE TV WILL NOT RESPOND TO ANY REMOTE SIGNAL OR DO ANYTHING, IS IT WORTH KEEPING TRYING TO FIX, I HOPE SO AS THIS WAS A GREAT TV
  • Sony Master
  • 19,396 Answers
Hi.
Red tint was caused by bad or no signal in blue and/or green channels of RGB videfind o signal circuits, which signal may start from AV tuner.
To start, how did you know that the problem was AV tuner?
If the problem was the AV tuner, then the TV would have worked OK by using an external receiver or a DVD for example.
If problem got worsening, more parts may have been damaged in this time.
Most of the video signal elaboration is done by the main controller board. This and other parts must be tested at component level. That is the only way to find out where the problem is.
About the service manual, this is different depending if model is ending with TS2E or TS2U. The service manual is for the chassis, and not the model the manuals below are for this same chassis, even if the file indicates the 42 inches (boards are same), just choose between u and click Get Manual at the left:
TS2E
TS2U
regards.
Ginko
Posted on Nov 16, 2010
  • Sony Master
  • 5,138 Answers
Its possiable the Part you replaced did not hold up,I would return that Part get New one and see if that FIXs the problem .
Encompass Parts Distribution has Free Service Manual for this Model.
You might want to Look at Shopjimmy.com for Parts for this set.
Posted on Nov 08, 2010
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
When truning tv on, the screen is mute & green
Ur Main signal tuner board is deffective,must replaced get this problems solved.
Jan 13, 2010 | Samsung HPN5039 50 in. Plasma HDTV
No sound on Sony KE-42TS2
You need a new Q board, All audio processing and switching is handled by the Q board. You can get a Q board from this site http://www.moduslinkptstvboards.com/A1401920A-P8168.aspx
Dec 21, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Same problem with sony ke-p42m1
this might be a bad or temp sensetive tuner, why don't you try hooking up a dvd player to your video jacks and see if the problem is present while watching a dvd disc. If it doesn't then you may have to replace the small signal board(where the cable or sat feed hooks up to the tv).
Aug 03, 2009 | Sony KE-P42M1 42 in. Plasma Television
KE-42XBR900- SYSTEMS SHUTS DOWN ON ITS OWN
Replace the G board. I had same issue and Sony accidently sent me two boards. I will sell the other for $450
danmathieu@aim.com
Jan 28, 2008 | Sony 42XBR900 Television
Apple TV and Sony KE32TS2 Plasma TV
That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
Nov 18, 2007 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
61 Inch Sony Plasma KE-MR61 needs to be repaired
Ke series makes that an early plasma TV
that old will probably be throw away or requires the replacement of the whole printed circuit of the TV
or power source
if chinese built that circuity may no longer be available
any local mobile TV repairer can check that TV out for you
check out the internet for sony corporation south africa
for parts availability
Mar 30, 2017 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television Logo
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
