Question about Echo Garden
CHAIN SAW WILL NOT START,NEW PLUG GOOD SPARK AND IS GETTING GAS
  • 7,733 Answers
You forget to change the coil!
Posted on Nov 08, 2010
  • 11,896 Answers
Have you removed, dismantled and cleaned the carb? that is usually the biggest problem.
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Nov 08, 2010
    A dirty carb will allow gas to carb, but won't mix gas and air properly in the motor.
    If you have spark, then coil and plug should be fine.
  • sunil jose Jul 23, 2011
    watch the spark weather it have continuity or not,some machine may show spark while we crank but it does not spark all times.please check it with spare ignition coil and plug
  • Nate Stansfield
    Nate Stansfield Jul 26, 2011
    If you have no spark or intermittent spark, then either the spark plug is bad, or the coil pack is bad. They only have two bolts holding them on.
SOURCE: jonsred chain saw 455
Sounds like the needle valve is sticking open. Could be as simple as cleaning it.
Posted on Jan 31, 2009
Fog Horn
  • 17 Answers
SOURCE: Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
Not used in 10 years. Was there gas left in the tank? If so the carb is likely gummed up and may need to be taken apart and soaked in "Gunk" solvent and a new kit installed.
Posted on May 26, 2009
lemmingleejn
  • 173 Answers
SOURCE: echo chain saw 16 inch will not start
You need to play about with the timing adjustment.
You can adjust the timing by two different methods.
The first is to adjust the space on the spark plug.
The other is to adjust the gap between the contact, and the coil/magneto.
There ya go, FixedYa !))
Don't forget to rate, thanks.
Posted on Aug 01, 2009
dontbother10
  • 2220 Answers
SOURCE: husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Posted on Oct 02, 2009
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
Poulan chainsaw not getting any spark???
you might have a broken wire to the spark plug. Use a meter to check continuity on the wire.
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
New spark plug plus new air and fuel filter. Chainsaw will not start or even fire.
If there is a good spark and fuel getting to the plug there are only two reasons why it will not fire, sheared flywheel key knocking the timing out, or it has partly seized and has low compression.
Aug 09, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
New saw - will not start. Have put in premium gas/oil mix. Getting spark from plug when cord pulled. Hasn't even fired once.
It's possible the brake is on. Try pushing the brake forward then pulling it back until you hear it click. Then try cranking it again.
Sep 20, 2010 | Poulan Pro Chain Saw 46cc 20"
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Doesn't want to start. Replace carb and ran for few seconds, Make you think that it is not getting gas, but pouring gas into spark plug does not help and drying spark plug dose not help. Spark appears...
The spark should be blue and snappy. Try a new plug--any help? If not, it may need a new ignition module. Check the flywheel magnets--they should be quite strong. The module gap with the magnets underneath the poles should be about business card thickness. Check the air cleaner and muffler for plugging. Hope this gets it running!
Apr 07, 2010 | Poulan 1630 16" Chain Saw
Saw was running and quit checked gas and oil both are full
Check to see if you are getting spark. If you are getting spark then it is not getting fuel. Try sparying starter fliud in the carb. If is starts then stops. Take the fuel line off to see if something is obstructing the line. Also the fuel filter can be changed.
If you are not getting spark with the spark plu relace the plug. Also to check the spark, remove the plug and put a screw driver in the plug wire and ground the screwdriver. a spark should come off the screwdriver
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
check that plug is getting spark (remove plug, w/ cap attached hold tip of plug on cooling fin. pull starter rope, should see spark). if not receiving gas check filter in tank, if ok procede to carb possibly add a bit of starter fluid.
Mar 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Open Questions:
Garden Logo
74 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
