Question about Datalogic Falcon 4420 Handheld Mobile Computer - P/N 4420-11223 Barcode Scanner
Can't remember admin password. How do I reset? Win CE.
I forgot my admin password for my Dell C1765nfw Color MFP web interface. I changed it from the admin default, but do not remember the pwd. How do I reset it
You could try performing a hard reset. Keep in mind that this will reset ALL settings. Admin password should then be back at the default, which is admin.
Clear NVRAM from Tech Mode
  • Turn off the printer.
  • Turn on the power while holding down Left arrow,Right arrow, and Menu buttons.
  • Release these keys when "CE Mode" and "Password" is displayed.
  • Press Up arrow key twice and press the checkmark.
  • "CE Mode", "Printer" and "FAX/Scanner" are displayed. (Entered the CE Diag. mode.)
  • Press the checkmark key to select "Printer".
  • Press Down button to "Installation Set" and press the checkmark key to select.
  • Press Down button to "Clear All NVM".
  • Press the checkmark key twice to execute the test.
  • Power cycle the printer to return to the regular operating mode.
May 23, 2017 | Dell Computers & Internet
Tip
How to enable Windows 7 administrator account and reset lost Win 7 admin...
How to enable Windows 7 administrator account and reset lost Win 7 admin password
There are two parts for your Windows 7:
* Enable Windows 7 administrator account
* Reset lost Win 7 admin password
With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods.
Part I: Enable Windows 7 administrator account
Method 1: Use Command Prompt
The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt.
1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator.
2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear.
3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled.
4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account.
Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps:
1. Switch to log on Windows 7 with the administrator account.
2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account.
3. Click Create a password for your account on the screen.
4. In the coming screen, type and confirm your Win 7 admin password.
5. Enter password hint and click Create Password.
Now your Windows 7 admin password is successfully created.
Method 2: Use Local Users and Groups
1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up.
2. Double-click the Users folder. And all the Windows 7 account will be displayed for you.
3. Right-click the Administrator account and select Properties.
4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen.
Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below:
1. Right-click the Administrator account and select Set Password.
2. Click Proceed to go on your operation
3. Type and confirm your new Win 7 admin password and click Ok
4. Close the Local Users and Groups screen.
Now the Windows 7 administrator password is assigned to your Windows 7 admin account.
Part II: Reset lost Win 7 admin password
Windows 7 administrator password reset Tips:
Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows.
Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password.
step 1. Download and install Windows Password Breaker.
step 2. Run the program and burn a Windows password reset disk.
Step 3. Reset Windows 7 administrator password with the disk.
It is an easy and safe way for Windows 7 admin password reset.
on Nov 02, 2010 | Computers & Internet
How do I reset the password for windows ce
Download Win CE as an ISO and bun it to a usb drive then reload your system.
Oct 06, 2014 | Sylvania Wireless Smartbook - SYNET07WICV
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
How to reset admin password
Reset Windows 7 admin password is not hard in fact, as long as you follow these methods to do.
Method 1: To Reset Admin Password with Administrator Account
On Win 7 logon screen, click user and "Switch user" to choose another administrator to sign into. Turn to Control Panel and navigate to User menu. Choose the account you want to reset its password, and remove its password. And then set a new password for it.
Method 2: Reset Admin Password with Password Reset Disk
You have two ways to get password reset disk. One is create it when you still have the administrator password. The other is to create it with third-party software, such as Windows 7 password genius.
Similarly, on Win 7 logon screen, after type wrong password, click link "Reset Password" to go on. Or insert password reset disk into Windows 7 computer and boot it from disk. Windows 7 Password Genius runs, at the same time, all accounts and password list for you. Choose the administrator account, and click "Reset Password" to finish Windows 7 admin password reset.
May 29, 2013 | Samsung SRD-440-500
Reset the password for windows ce on my netbook?
If this is a SYNET07526 using Win CE, then you will have to re-flash the system in order to get rid of the password that you have forgotten. See my TIP for flashing the SYNET07526 at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
May 19, 2011 | Sylvania G-Netbook
Son cannot remember the password/admin password to boot his dell inspiron 2200 win xp i am willing to reinstall win xp but dell wants twice the cost of what this box is worth.
The only solution I can offer is, go to www.ebay.com type in laptop, make and model, administration password, you should get a list of software that should help, remember when you purchase, it is for win xp
Jan 07, 2011 | Dell Inspiron 2200 Notebook
I no longer remember my password, how do I reset it to something I can remember?
Pressing the button on the back until the power light flickers (about 10 seconds).It will reset the configurations in to factory default.
default admin user name: admin
default admin password : password
Dec 28, 2010 | NetGear WGR614 Wireless Router
Can't get into laptop, admin password i HAVE FORGOTTN
You have not mentioned ur OS, any how for win XP follow the link below to download a free software to unlock ur win XP admin password.
http://www.sharewareconnection.com/download-windows-xp-password-reset-software-from-sharecon.html
Hope this will solve the problem
Sep 20, 2009 | Toshiba Satellite 300CDS PC Notebook
Neoware thin client password recovery Windows CE
Use Administrator The "A" is capitaized only....worked for me...administrator with Administrator for password!!!!
Drew
Apr 02, 2008 | Neoware CAPIO 620 (cp4h-bb-aa0) Network...
Datalogic Falcon 4420 Handheld Mobile Computer - P/N 4420-11223 Barcode Scanner Logo
107 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
jackcity
jackcity
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
