Question about Xerox DocuColor 3535 Copier
Xerox 3535 have lost my nvm settings how do i put them back on my machine
  • tony1234567 Jun 24, 2008
    windows xp
    someone reset my machine cause of an error code ant now when i print all colours are out of fit
  • Xerox Master
  • 13,433 Answers
Did you perform a reset which removes these settings? before doing such reset one should print out the settings.
see the manual in this address for instructions on how to re enter settings into the printer
http://download.support.xerox.com/pub/docs/DC_3535/userdocs/any-os/en/dc3535_en_customer_user_guide.pdf
system settings can be found on page 140 or 4-2 if looking at the markings in the pages.
Posted on Jun 20, 2008
  • Ekse Jun 25, 2008
    you should have been albe to solve the problem with the solution i provided earlyer.
    What is the problem can you clarify?
  • 2,071 Answers
I think all the technic is given already and yet not solve..unfortunately it is difficult to diagnose like this problem best get it by to the authorized service center they know everything there...
Posted on Jun 25, 2008
    Genius:
  • 1,665 Answers
    Master:
  • 848 Answers
Just check this website to solve your problem
http://www.support.xerox.com/go/results.asp?Xlang=nl_NL&XCntry=NLD&prodID=DC_3535&ripId=&Xtype=download
Posted on Jun 24, 2008
    Sergeant:
  • 260 Answers
Can you give me the name of the operating system you are running. Resetting the NVM usually requires a "patch" for your specific system. If you have lost those settings, then we need to go back to the drawing board and reproduce everything you added to your O/S and computer drivers that runs the computer.
  • Xerox Master
  • 19,396 Answers
If you lost non volatile memory settings, all you can do is reset them to factory default, as the machine does not keep backup of settings.
go to diagnostic test and adjustments menu and select code 0360, or set all nvm parameters to 1 (default), or follow instructions here .
Regards
  • 4,472 Answers
Can you be more specific as to what the "nvm" settings are? I am having trouble finding anything by that name in the manual.
Thanks,
lee
Posted on Jun 23, 2008
  • Lee A.
    Lee A. Jun 24, 2008
    Is there something more you needed help with. You have gotten the correct solution for your problem. If you need further assistance please clarify. You should have found something helpful and it is greatly appreciated that you rate accordingly.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 24, 2008
    1 Program the features and options you want to save for future use.
    2 On the Job Assembly tab select Stored Jobs.
    3 Select Store.
    4 Select the desired icon to identify the job number.
    5 Select Enter/Change Name to name the job.
    6 Select the job number.
    7 Enter a name up to 18 characters long for the stored job and
    select Save.
    8 Select Close.
    That is how to store a job.
    Hope that helps. If you need anything further I will need more detail as to what you are looking for.
    Thanks,
    Lee
    Master:
  • 788 Answers
If you lost your settings because you reset the printer or you performed on upgrade then unfortunately they are gone.
Usually the only settings that really need to be set are the network settings in order to get you printing again. If you don't know what the network settings should be you should be able to get that information from any computer on your network. Look at the port settings in the printer's properties and you should be able to get the IP address of the printer. The subnet mask and gateway can be found by running ipconfig from a command prompt, type "cmd" in the Run dialog to get a command prompt. Most other settings are rather general so go through them and change them if you need, but setting up the network is important. Look at page 182 in the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
  • 1 more comment
  • Dean Joly
    Dean Joly Jun 24, 2008
    Are you having trouble getting the printer back on your network? If so and the instruction I provided earlier are too vague please let me know and I will clarify. Let me know what version of Windows you are using and if you have a print server on your network. Thanks.
  • Dean Joly
    Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/do...
    Here is what it says:
    Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
    tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
    NOTE:
    Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
    Copy Job - Text
    Compensates tones when a text original is copied.
    Copy Job - Photo
    Compensates tones when a photo original is copied.
    Print Job
    Compensates tones when printing with controller line screen.
    Network Controller - 1
    Compensates tones when printing with Network Controller screen type 1.
    Network Controller - 2
    Compensates tones when printing with Network Controller screen type 2.
    NOTE:
    Printing the chart for Auto Gradation does not increase the meter count.
    NOTE:
    When gradation adjustment is executed, the following
    changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
    NOTE:
    When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
    On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
    Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
    Select the desired gradation adjustment screen:
    • Copy Job - Text
    • Copy Job - Photo
    • Print Job
    • Network Controller - 1
    • Network Controller - 2
    Press Start. The Adjustment Chart is output.
    Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
    5
    Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
    6
    To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
    7
    Select Exit to exit the System Settings mode.
  • Dean Joly
    Dean Joly Jun 25, 2008
    Did you try the Auto Gradation Calibration as I suggested yesterday?
    Master:
  • 638 Answers
You need to reset the printer in service mode. Additional functions, #. scroll to printer, then printer reset. If this doesn't work then you need a new fuser.
LINK FOR ADDITIONAL INFORMATION :
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
    Brigadier General:
  • 3,614 Answers
What is the exact model of your unit
    Genius:
  • 3,422 Answers
Please CLICK HERE to view the user manual.
Dc 236 machine has a fault code 010-320. fuser is new, lvps is new and so the small board, i dont know the name of that board... but still 010-320 is there... trying to reset the value of nvm from 2 to 0,...
Well since you know how to enter diagnostics. Go to DC132 and select all copier nvm. Do an all copier nvm initialization, it will correct any default errors in the memory.
You will just have to then reset things like the power save timers and I would also go in and do a dc604 registration adjustment.
Apr 18, 2011 | Xerox DocuColor 3535 Copier
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
Error 010348
over heting of fuser unit
can be reset by NVM read/write
744-003 set to 0
Jan 11, 2010 | Xerox DocuColor 3535 Copier
Reset fault code 010-348 xerox 3535 copier i have replace the fuser with new
wait until the machine is in the 'Ready' state, then on the Control Panel, select [9] and [AC] simultaneously. A message will be displayed asking if the Fuser Cartridge was replaced, select [Yes].
Jan 01, 2010 | Xerox DocuColor 3535 Copier
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser for another new one and still get it so suspect I need to do an NVM setting but don't know which? Can...
4-361 Drum Motor
Drum Motor failure.
Initial Actions
• Remove all Drum Cartridges.
• Perform REP 1.6.
Procedure
The machine is a DC3535.
Y N
Enter dC330 [004-003] and press Start. The Drum Motor energizes and the drives
rotate.
Y N
Go to Figure 1 of this procedure and measure voltage between the Drum Motor P/
J210-4 (+) and GND (-). +5 VDC is measured.
Y N
Go to Figure 3 of the +5 VDC Wirenets and troubleshoot the problem.
Replace Drum Motor (PL 1.1).
Dec 01, 2009 | Xerox DocuColor 3535 Copier
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Error code 010-348
Hi go to system settings and then go to NVM location then type 744-003 and then change the value in the lower field to 0.
Jun 26, 2008 | Xerox DocuColor 3535 Copier
298 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
