Question about Comtrend CT-507 Router
My isp says it only uses wpa i neep wep to play ds games online can you help
  • 38 Answers
Try to lower down the security level of your router to WEP. CT-507 Router has WEP feature.
Posted on Nov 09, 2010
Ds lite wi fi connect wpa
Try changing your WiFi encription to WEP or no security, this should be available on your cablemodem/router web internface (need a user and password for that) under the Wireless/Security option.
DS Lite is not compatible with any other WiFi encription for online gaming: "Important note about the Nintendo DSi and WPA security: While the Nintendo DSi is compatible with WPA security, Nintendo DS games with online play still require the use of WEP or no security to connect with the Nintendo WFC. Therefore, your connection settings for using these games must be set up on slots 1-3. If you need more details on using your adjusting your router's settings,click here and select your router (if available).
Nov 04, 2013 | 2wire Computers & Internet
How do you connect to the internet?
If you have wifi in your area, you want to go into the settings and configure your internet connection, Nintendo includes a very helpful wizard that should get you going.
If I can get a little technical for a second: The DSi supports more Wireless security types than the original DS or DS lite. Because of that it will recognize and connect to WPA2 and WPA encryptions as well as WEP. The old DS and DS lite only supported WEP. Because of that, if you are trying to play games online, you will need WIFI that is only secured with WEP or not at all.
Jul 21, 2011 | Nintendo Dsi Pink Console
Im not able to use Nintendo Wi-Fi Conection because of a communication error.My error code is:51099
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Jun 26, 2011 | Nintendo DS Lite
I can not get connection
Jun 25, 2011 | Nintendo DS Lite Console
How to put internet on it?
Jun 24, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
How do you get the internet on this my says no compatible access point in range check your connection setting under internet opion and try again error code 051099
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
  1. Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step.
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
mr_fix3er_0.png 2- Scroll over to the third page, and select "Internet."
mr_fix3er_1.png 3-Now choose "Connection Settings."
mr_fix3er_2.png4-Click on "None" for "Connection 1."
mr_fix3er_3.png 5-Click on "Search for an Access Point."
mr_fix3er_4.png 6-The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network.
7-What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
mr_fix3er_5.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_6.pngWEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_7.pngWPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
  • Other suggestions :
  • Make sure your router is set to broadcast in "b" or "mixed" mode. If your wireless router is transmitting in "N" only mode, you will need to switch it to "b/g" or "mixed" mode. For help accessing your router's settings, click here and select your router brand and model (if available). Most routers will have this setting in the "broadcast settings" menu.
    • Check for wireless interference, which can affect the signal strength to the Nintendo DS. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Nintendo DS is an open area without objects or electronics blocking the signal.
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • Still stuck? We can help! We have found that simply erasing the old connection file and creating a new connection to your router may help. Click the button below for a step-by-step guide. If at the end you still need help, you'll find contact information to reach our specially-trained representatives. Click the button below for your system and we'll walk you through the connection step-by-step.
    Apr 14, 2011 | Nintendo DSi Matte Blue Console
    Error code 051100-1
    If you would like to utilize the online features of Nintendo DS games, you will need to change the security to WEP or no security. Nintendo DS games are not compatible with WPA security.
    If you would like to stay with WPA security, you will need to used the advanced settings in your Nintendo DSi.
    Please visit the following page for more information:
    http://www.nintendo.com/consumer/wfc/en_na/ds/wrWEPkeyHelp.jsp
    Mar 06, 2011 | Nintendo DS Lite Console
    Can not get on the internet error code 051099-9
    Try this:
    Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
    Other suggestions:
    Feb 01, 2011 | Nintendo DS Lite
    How do you get internet on dsi \
    Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only). Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
    Hope this helps
    Nov 30, 2010 | Nintendo DS Lite Console
    Switching from WPA to WEP security on wireless
    This is a frustrating problem that I also have. There are a couple of things you can do, but the easiest would be to pick up another cheap wireless router. Before you do so, make sure it's on the list on Nintendo's site of routers that will work.
    http://www.nintendo.com/consumer/wfc/en_na/ds/routerInfo.jsp
    My solution was to use the lower strength WEP security, despite its problems. I bolstered it with MAC address filtering, and I'm trusting my physical distance from the street to cover the gap in the security as well.
    Other solutions include creating an access point using your computer itself, if it has that capability. Modern Macs can do this easily using the built-in airport card. If you need help with any of these solutions, I would be happy to help you out.
    Jan 08, 2009 | Nintendo DS Lite Console
    Comtrend CT-507 Router Logo
    81 people viewed this question
    Top Comtrend Computers & Internet Experts
    Julie Endres
    cwradio73
    Prashant M
    Prashant M
    Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
