Question about Frigidaire Affinity ATF6000F Front Load Washer
Hi there I have a Beko wm6152w, the Start/Cancel light and the Ready light are green but when I click on the start button it does not do a thing!!! how can I fix it???
3 Suggested Answers
kakee
  • 1269 Answers
SOURCE: Same problem. Dishwasher won't start and wash light blinks.
If the wash light is blinking, there's an internal component problem there. Mainly the fuse is blown if it's blinking. Try to unplug the power of the unit overnight to reset it. If the same problem occurs, better have it repaired. If you can manually check the back panel of your machine to see if there's an open or shorted wire there, resoldering them could possibly fix it. The last resort is to contact a repairman to replace the burned internal electronic component.
Posted on Jun 30, 2009
SOURCE: beko wm6152w turn machine on
try holding the start/pause button in for five seconds, hopefully it will restart
Posted on Aug 29, 2010
WM6152W instruction manual
Sorry but Beko discontinued this product and so they don't have the manuals on their site,Click on the link below to browse the available models.
http://www.beko.co.uk/Products/Manuals?pagetitle=Manuals
Hope this helps.Thanks!
Ken.
Jan 11, 2012 | Washing Machines
How to fix B200 E30 error for mp198
A. Entering into service mode
  • Turn off the printer off is the printer power on. And remove the printer USB cable from your computer..
  • While the printer is OFF, press and hold the Start/Stop button on the some other canon printers model press Resume/Cancel button.
  • While still holding Start/Stop button or Resume/Cancel button, press and hold the POWER button.
  • When the POWER LED (green light) lit, release the Start/Stop or resume/cancel button (still holding the POWER button).
  • Still holding the power button, Press the Start/Stop button or resume/cancel button TWICE then Release the POWER button. Wait until LCD printer to display 0 (zero) number
  • After the display is 0, attach the printer UDB cable to your computer, its will detected new device installed (its normal), now go to resetting steps
B. Resetting Ink counter on the Printer
Run "service_tool 1050.exe". you can download the service tool software from this link:
http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
  • Confirm detected USB-port numbers on USB port column.
  • Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete.
  • Click "platen button" on the "Clear ink counter" section. The printer will print again.
  • Turn off the printer and then turn the printer on. You printer is ready for use.
Aug 08, 2011 | Office Equipment & Supplies
Hi, iv'e lost my manual for beco dryer
Try Googling (beko)(model)(manual) without parens.
Jul 19, 2017 | Dryers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Leave power on.
Apr 26, 2008 | Washing Machines
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Frigidaire Affinity ATF6000F Front Load Washer Logo
133 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
