Question about Linksys RV082 Router (RV082-AU)
I have RV082 Router , and Diag Led is constant what to do
  • Linksys Master
  • 7,733 Answers
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Posted on Nov 09, 2010
My router rv082 is rebooting automatically
I'd try flashing the firmware and if that doesn't resolve it, replace it.
Nov 23, 2012 | Linksys Cisco Rv082 Dual Wan Router 30...
I need to connect two RV082 routers with a cross over cable and setup a tunnel between them, Is that do able
That should be doable. You will need to set a manual IP address on both since the default would be to get an IP address automatically.
Why do you want to do this? Normally this would be to connect two remote locations.
May 10, 2011 | Linksys RV082 10/100 8-Port VPN Router...
In my office we have linksys RV082 as our internet router, we use VSAT C-Band type with 1.5 Mbps ratio 1:4. The problem is when we try to test internet speed from client (Modem ->Router RV082...
I think that this is a configuration issue, which can be resolved by re-configuring the router.
Please refer to the Product Manual for details about configuration and management of bandwidth.
Hope it helps!
CreativeTECH
Nov 25, 2010 | Linksys RV082 Router (RV082-AU)
I lost power and when I unplugged and replugged the router, the only light that come on are the power and diag light
Hi!
You need to folloow the steps below if Diag Led lights keeps on flashing overtime:
Click start then access control panel Go to Local area connection - properties - internet protocol/TCP-IP then use the IP Address: 192.168.1.50 and Subnet Mask:
255.255.255.0. after these download the most recent firmware version for your router that can be downloaded from your router's manufacturer website. Restart your devices after firmware version upgrade.
Should you have any other questions just please leave a message.
Cheers~
Sep 09, 2010 | Linksys Wireless-G Broadband Router
Red diag light flashing
This is happening because the firmware did not load correctly.
Please follow the link below and follow the instructions. there are many steps to use to resolve this.
Hope this helps!
Jim
http://www6.nohold.net/Cisco2/ukp.aspx?pid=10&login=1&app=search&vw=1&articleid=4861&donelr=1
May 30, 2010 | Linksys EtherFast Cable/DSL Router
Backup of RV082
gotta love the translation to english. Preferences just means the changes you have made. ALL of them.
Mar 09, 2010 | Linksys RV082 10/100 8-Port VPN Router...
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Feb 14, 2009 | Linksys RV082 10/100 8-Port VPN Router...
Power and Diag lights blink.
When the diag and power light always blink it only means one thing there's a problem with the router, Try tor eset it by pressing the reset button for 30 seconds then after that tunr off the power for 5 seconds then trun it back on, of the diag and power light are still blinking the router is already bad and needs a replacemenet, If the router is still under warranty have it replace to Linksys this is the number 800-3267114.
Hope that helps.........
Aug 29, 2008 | Linksys Wireless-G WRT54G Router
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
Linksys RV082 Router (RV082-AU) Logo
700 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
