Question about Electrolux Washing Machines
Electrolux Ecovalve 7 kg washer is displaying eE20 after being recently moved to a new property and reconnected. What does this mean and how do we fix it?
4 Suggested Answers
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
Daniel S
  • 4323 Answers
SOURCE: My electrolux EWF1087 ecovalve just flashes "Err"
Hi
If it just gives ERR code then let's try and get the error code out of the washer. To do this turn the washer on to any cycle and light it up, after this press and hold the START/PAUSE & RESET button together for around 20 seconds. Now either the washer will reset or will tell you a error code E followed by a number, let me know the error code so that I can tell you what the issue is. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 09, 2011
ginko
  • 19396 Answers
SOURCE: Washer does not spin when
Hi.
Parts such as drain system, drain pump, pressure switch, door switch, motor, motor control unit and control panel may be responsible for drain problems.
Check the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
Access the drain filter. With most front loaders this located in front at the bottom in a corner, there should be a trim or an access panel.Top loaders have an access panel at the back, or more commonly the pump is accessed from underneath, bending the appliance on one side and securing it.
The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is often in control assembly. Clean the hose and the switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.
The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is working or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Most machines have a tech booklet tucked inside the control panel assembly. You take off panel that is held by a couple of screws and see if there is the envelope with the sheet
Here a page about drain/spin problem.
Start checking drain hose and drain filter. If machine is a front loader the drain filter access is located behind the door at the front bottom side of the machine.
Posted on Sep 09, 2011
Hi washing machine will not stop filling Electrolux Ecovalve EWF1087
Without seeing what make and model... Pressure hose to the water control might be plugged or tap on the control panel with a rubber mallet to see if points in that sensor are stuck. Try setting it to a smaller load size.
Apr 10, 2016 | Washing Machines
What does error message F-10 mean
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
Electrolux Inspire 7 kg washing machine. Error code 22. A program run for 30 minutes Ok and the stop and reset the program. What means e22 and how can be solved? Thanks in andvance!
Hello Serban Alexandru - Typically error code E22 indicates that the water is not pumping out fast enough. Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have the pump, timer or main control board diagnose.
Oct 04, 2012 | Electrolux Washing Machines
Hi I have an electrolux 7kg ecovalve ewf087 - it first started with the place where I put the washing powder etc filling up with water after the cycle- so I thought I would clean the drain pump filter...
Make sure you put the filter cap on tightly There is a little plastic piece it has to line up with, Recheck all the hoses. Remove the access panel and start the washer see where it is leaking. If you need further assistance please comment me back.
Jul 30, 2011 | Electrolux Washing Machines
Cannot open the front door on an Electrolux ECO 7 kg front load washing machine. Feels as trhough the door clip has broken
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
Jan 10, 2010 | Electrolux EW1200i Front Load Washer /...
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
Jul 22, 2008 | Electrolux Washing Machines
Washing Machines Logo
432 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
