Question about Ford 8n,9n,2n, Tractor Starter With Drive
The bendix drive on my 1949 ford 8n tractor does not engage all the time. It requires a light tapping with a hammer on the side of the starter to cause the bendix to engage. The first starter that I replaced worked fine for a couple of months then the bendix drive came apart, literally. The replacement starter demonstrated the same problem with the bendix drive right out of the box. The starter comany does not know what the problem is, and say it is my tractor. However, I bypassed the electircal system by jump starting the starter and had the same problem
  • bc28 Nov 10, 2010
    thanks for reply. I have converted to a 12 volt system. Battery only couple years old too.
    Bendix drives were dry out of the box. Lube with motor oil, bearing grease, or something else?
    Thanks again
  • Ford Master
  • 5,687 Answers
I have a tractor like this too. A lot of the problem is the RPM of the Starter shaft. Make sure you have a 6 Volt Armature if you are still running the 6 Volt Battery. There are 2 different Bendix drives, the old style which is the long style and the newer Automotive short style.
To get the shorter Automotive style to fit inside the Bell housing you have to use a Die grinder and make a little room. You may find the Website, Dennis Carpenter.com beneficial. Valu-Bilt is another tractor parts source.
There is a referral to an Improved Ratchet type Starter Drive. You might ask the Re-builder if the part you have is suppose to fit an NAA type tractor. My books show it would be the wrong part if it does. I have read a lot of Parts books and seem to remember some of the Bendix gears were 9 tooth and some were 10 tooth. Your Ring gear is suppose to have 134 teeth.
I believe you are better off testing the Starter before you install it. You may want to check the Starter Draw on a bench at Autozone or Oreillys. The lower the draw, the better the connections are. If you are dealing with a Tractor place, they can certainly bench check the unit.
You may need a stronger Battery with more pop in it Have your Battery load tested too, you may be surprised. When I rebuilt my 8N starter I really did not care for a few plastic components I found inside it. You are going to need to lube up the Bendix good to keep it sliding. Refer to the 2 Websites I gave you for more details. You can always use the Reply feature to update a comment.
Posted on Nov 08, 2010
  • fordexpert Nov 11, 2010
    I think the best lube for this is the Silicon grease they sell for Brake Caliper bolts. This is the stuff they put into the Caliper boots and brake pad contact points to keep the Calipers from freezing up.
    Figure it protects from about everything (water, dirt, heat) and its made to be used when you bolt up the part and its no maintenance after that.
Ford 8n Is It Time to Replace the Starter?
Bad brushes it is not making contact with the brushes.
Jun 22, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
The bendex in stuck to the flywheel on my 8n
I have the same problem as Derek. I pulled the casing off the starter and the armature along with the Bendix stayed stuck in the bell housing. I tried tried putting the tractor in gear and rocking it back and forth with hopes that the bendix would pul away from the flywheel. No luck. I think I'm going to have to pull the thing apart.
Mar 24, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
New starter motor and bendix. will not engage with flyweel. starter motor just spins.
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
Nov 08, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
Starter spins but does not seem to engage to fly wheel
Odds are that you have a broken spring in the bendix part of the starter drive,which is replaceable but at the same time is hard to find separate from the whole assembly.The whole assembly will run you about 55 to 90 dollars depending on where you find it.
Jul 29, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
How do I remove the starter on a Ford 8N tractor?
Funny you should ask. I just got in from doing just that.
1: Disconnect the battery
2: remove the seloniod (I just unbolted and unscrewed it from the starter and left the wires on it so I wasn't trying to guess what went where later when I get back to reassembling it.)
3: you have 2 bolts at the rear of the starter (the part of the starter that faces the front of the tractor.) You unscrew them to take the starter out. BE CAREFUL - if you pull the starter apart it will be a bear to get the brushes back in.
I had the additional problem of the "bendix" (the part that engages the flywheel) jumping over the flywheel so I needed to remove the bolts on the canister to the left of the starter and move it slightly out of place in order to complete the project. You may not have to do that but I mention it as a aid because I don't know why you're changing out starters.
In my case I found that although the starter was spinning the shaft was being chewed up because the engager (bendex - whatever its called) had jumped the flywheel and was resting against the flywheel. Really needed extra space to pull the starter because of that.
Also saw somewhere that that bendix needs to be drawn in in order to reinsert the starter (something about having to spin it in??? I'll be looking for that shortly myself.
Jan 13, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
My 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Nov 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Need to replace 9n tractor starter when you turn ignition key the starter just keeps going around.
I suggest that you pull the starter and make sure the bendix unit isn't stuck on the shaft which may be rusted or dirty and corroded first. If the starter spins then the starter itself is probably okay. Hope this helps you
Oct 16, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 4000 starter only works when I hit it with a hammer. What does that indicate?
the bendix unit on the starter shaft is sticking. You need to pull the starter and clean the shaft up and lightly grease it so the gear can move out when you engage the starter. worst case scenario you may have a badly worn shaft and need to replace it with a new starter. hope this helps you...
Sep 15, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
923 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
