Heating & Cooling Logo
Posted on Nov 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Solenoid Valve will not open - Heating & Cooling
Anonymous
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Nov 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
81
Questions
Helped
46270
Points
162
Check the power to the valve if there is power to it you valve is stuffed. you can also take valve of and put a insulated screw driver in the middle to see if there is any magnetic fource pulling it to the side. .. the solenoid valve is for a reversal valve ?
2-3 shift solenoid circuit
P0758 Chevrolet P0758 Chevrolet - 2-3 Shift Solenoid Circuit Electrical
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty 2-3 Shift Solenoid Valve
- 2-3 Shift Solenoid Valve harness or connectors
- 2-3 Shift Solenoid Valve circuit is open or shorted
What does this mean? When is the code detected?
When the Powertrain Control Module (PCM) detects a continuous open, short to ground or short to power in the 2-3 Shift Solenoid (SS) valve circuit, then DTC P0758 sets.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission will not shift gears
P0758 Chevrolet Description
The 2-3 Shift Solenoid (SS) valve controls the fluid flow acting on the 2-3 shift valves. The 2-3 SS valve is a normally-open exhaust valve that is used with the 1-2 SS valve in order to allow four different shifting combinations. The solenoid attaches to the control valve body within the transmission. The Powertrain Control Module (PCM) controls the solenoid by providing the ground path.
Read more: http://engine-codes.com/p0758_chevrolet.html#ixzz3kcwzXFmK
Trouble codes po758 p0758d
P0758 Problem in Shift Solenoid Valve B Circuit
Fault :
Solenoid Valve 2 B - Open or Short to Earth or B+
Cause:
Wiring/Connectors from/to Solenoid Valve 2 Open or Short to earth.
Solenoid Valve 2 (N89) faulty.
Engine control module (ECM)/Powertrain control module (PCM)/Transmission control module (TCM)
Solutions:
Check/Repair Wiring/Connectors from/to Solenoid Valve 2.
Check/Replace Solenoid Valve 2.
Quest code p1136
P1136 NISSAN - Intake Valve Timing Control Solenoid Valve Circuit Bank 2
Possible causes- Intake valve timing control solenoid valve bank 2 circuit is open or shorted.
- Intake valve timing control solenoid valve bank 2 circuit connectors
- Intake valve timing control solenoid valve bank 2 Tech notes Since the Intake valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code.
2helpful
Nissan code p1136 p1124
P1124 NISSAN - Throttle Control Motor Relay Circuit Short
Possible causes- Throttle Control Motor relay harness is open or shorted
- Throttle Control Motor relay circuit poor electrical connection
- Fualty Throttle Control Motor relay
2helpful
Codes po740, po743 ? po753 all at once. Where should i begin for repairs?
You must do the diagnostics for each code.
Here are the possibilitesP0740 DODGE - Torque Converter Clutch Circuitxicon.jpghttp://engine-codes.com/p0740_dodge.htmlForum CodePossible causes- Low transmission fluid level
- Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness or connectors
- Torque converter clutch solenoid valve circuit is open or shorted
P0743 DODGE - Torque Converter Clutch Solenoid Circuitxicon.jpghttp://engine-codes.com/p0743_dodge.htmlForum CodePossible causes- Faulty torque converter clutch solenoid valve
P0753 DODGEP0753 DODGE - 3-4 Shift Solenoid Relayxicon.jpghttp://engine-codes.com/p0753_dodge.htmlForum CodePossible causes- Faulty shift solenoid valve
- Shift solenoid valve harness or connectors
- Shift solenoid valve circuit is open or shorted
Po401 ive cleaned the egr & replaced the egr but i keep getting this code??
depending on your model, there may be a solenoid valve that turns the vacuum to the egr valve on. If the solenoid fails, the egr valve will not open. Follow the vacuum line on the egr valve--does it go to a solenoid valve? If yes, apply 12 volts directly to the solenoid blades to see if it clicks open. If it doesn't click, replace the solenoid.
2helpful
What is po411 and po445 for 2006 vw jetta/
P0411- Means Secondary Air Injection System Incorrect Flow Detected!
Possible causes - Vacuum hoses damaged.
- Air Pump inoperative.
- Air bypass solenoid circuit open.
- Air bypass solenoid leaking/blocked or stuck open/closed.
- Air diverter valve leaking/blocked or stuck open/closed.
- Air air hoses r Possible solution - Visually inspect vacuum lines for disconnects in the AIR systems and visually inspect for proper vacuum line routing. Repair if necessary.
- Disconnect the air pump hose at the solenoid valve, start the engine and see if there is air being pumped P0445- Means Evaporative Emission Control System Purge Control Valve Circuit Shorted! Possible causes - Damage harness or connectors to the Purge Control Valve
- The valve circuit is open or shorted
- EVAP canister purge volume control solenoid valve may be faulty
P0445 Description The EVAP canister purge volume control solenoid valve uses a ON/OFF duty to control the flow rate of fuel vapor from the EVAP canister. The EVAP canister purge volume control solenoid valve is moved by ON/OFF pulses from the ECM. The longer the ON pulse, the greater the amount of fuel vapor that will flow through the valve. When is the code detected? - An excessively high voltage signal is sent to ECM through the valve
Water runs to the solenoid, but doesntt pass through it... Do I need a new solenoid?
Check to see if you are getting 24 volts to the solenoid valve, if you are but the solenoid valve does not click open then the valve is most likely bad. Another thing you can do is apply 24 volts directly to the solenoid valve from the transformer if it does not open then the vlave is bad.
5helpful
2answers
Torque convertor clutch circuit electrical code po743
CIRCUIT DESCRIPTION
The shift solenoid valve SL is turned ON and OFF by signals from the ECM to control the hydraulic pressure
acting on the lock–up relay valve, which then controls the operation of the lock–up clutch.
DTC No. DTC Detection Condition Trouble Area
P0743
 ECM detects open in solenoid SL circuit 4 times when solenoid
SL is not operated (2–trip detection logic)
 ECM detects short in solenoid SL circuit 4 times when solenoid
SL is operated (2–trip detection logic)
 Open or short in shift solenoid valve SL circuit
 Shift solenoid valve SL
ECM
Fail safe function
If the ECM detects a malfunction, it turns the shift solenoid valve SL OFF
Top Heating & Cooling Experts
Paul Carew
john h
