Hotpoint 24 in. DWF32P Free-standing Dishwasher
Problem for Hotpoint 24 in. DWF32P Free-standing Dishwasher
Dwf50 hotpoint aquarius dishwasher
By j0childs on Jun 16, 2008
my dishwasher dwf50 hotpoint has 2 lights flashing, it starts a cycle then the lights flash together, the delicate load and fast load then stops altogether, i have filled the salt and rinse aid, please help
Same Problem
Feb 17, 2009
-   i have the same problem and thought it was the rinse aids and salt but seeing as you've tried it then it can't be the problem? have yu found a solution at all?thanks-   recruitcob
Jan 01, 2009
-   when used it nevers seems to wash properly and both the "fast" and "delicate" lights flash at the end of the cycle, the manual gives no reason for this "code"-   dmnc795
Dec 20, 2008
-   I am having the same problem with the DWF50 dishwasher model-   Guest
Nov 29, 2008
-   I have the same -   Guest
Nov 11, 2008
-   i have the same problem-   alexrapley
Best Solution
posted on Jun 22, 2009
Very Helpful)
trainsp375
Rank: Apprentice
Rating: 100%, 1 votes
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hotpoint 24 in. DWF32P
Questions and Unsolved Problems for Hotpoint 24 in. DWF32P
Do you recommend Hotpoint 24 in. DWF32P Free-standing Dishwasher?
Answer
Answer
crockery is still dirty after a wash cycle.it also appears that there is'nt enough water being used... (More)
Answer
my df32 stops when it should take in its first intake of water
Answer
hotpoint dwf31 ,when i start cycle the timer does not go down and water doesent get hot
Answer
Buttons 3 & 4 flashing, machine stopped on Wash cycle with water inside.
6 Other Users Have The Same Problem - Continued
Comment by deedee41, posted on Jun 25, 2008
2 lights flashing and it won`t carry on any ideas
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. DWF32P...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
