Question about Brother LS-2125 Mechanical Sewing Machine
Threading a machine manually
Need help threading a comercial machine
  • 1 more comment
  • Anonymous Jul 06, 2008
    Everytime I thread the upper part, when I go to sew, it does a couple of stiches then the thread comes out of the needle. HELP! TY
    My thread keeps coming loose after a couple a stitches. It comes right out of the needle.
  • Anonymous Mar 27, 2009
    I need a picture of the threading.
  • 323 Answers
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.Industrial needle shave no flat side. You need to find the long groove on the needle and insert it so that it is on the left.Thread the needle left to right. Draw up your bobbin thread and begin.
sewman7
Posted on Jun 17, 2008
I DO NOT HAVE A MANUAL FOR 8708. I ALSO AM HAVING TROUBLE WITH THE UPPER THREAD,( PROPER THREADING NEEDED,) IT KEEPS BREAKING, PLEASE HELP. VINCENT
The manual may help (assuming this is your machine):
Crofton MD 8708 Instruction Manual
The thread will break if the machine is threaded incorrectly. Be sure to ALWAYS RAISE the presser foot when threading the upper thread. Also, set the upper tension to the midway point. This is the standard setting for machines although there may need to be some tweaking to get the tension where you want it.
Oct 20, 2016 | Sewing Machines
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
I need the manual instru tions for euro-pro x 420
This is where to find what your looking for. http://www.sewingpartsonline.com/euro-pro-sewing-machine-instruction-manuals.aspx
Sep 04, 2016 | Euro-Pro Sewing Machines
I need to know how to thread a Janome 2008 and where is the bobbin
go google and type in-- operators manual for janome 2008 sewing machine --- down load a site that has a pdf version and it will have all the information that you will need
Aug 31, 2016 | Janome Sewing Machines
I have an Elna Funstyler sewing machine and when i sew zig zag the bobbin thread shows up on top, have tried changing tension and doesn't help. Is there any way to oil this machine? Instruction manual say...
If your thread tension is OK and u have correctly threaded machine, I would check manual for first the right bobbin and put in machine right. I have have issues from badly wound bobbins too. If you have replaced correct needle and your fabric, thread and tension are good, I would check manual for the right bobbin tension. Wish I knew more to help......
Dec 15, 2010 | Sewing Machines
How do I thread up a Riccar Reliant 57 sewing machine? I have just been given one and their is no manual. I will purchase one but need to use the machine now. Thanks.
HI
Try finding a threading diagram in a manual for another riccar machine here.
http://www.riccar.com/help/manuals/
I couldn't see a manual here for the Riccar Reliant 57 but there are ones for the RL570 etc.
Most machines by the same brand thread in the same way.
Hope this helps!
Oct 29, 2010 | Riccar Sewing Machines
Owner's manual
I found a website for you that might help. They have a lot of kenmore manuals including one similiar to your model#148.12051. The manual opened as model 1205 so maybe searching for your model as the 1201 might help too. hope this helps! =)
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/kenmore_sewing_machine_product_list.html
Feb 04, 2010 | Brother PC-420
How do I thread my Singer 7422?
I suggest you do a search on youtube on how to thread a sewing machine and choose a video showing a similar machine as there are really only about 3 basic types of machine as regards the threading.
Some of these instruction videos are very good and you will find it much easier than explanations. However-the important thing is that the thread must go between the tension discs by your tension regulator and do make sure you have a good need le in the machine, inserted correctly.
Jun 22, 2009 | Singer 7422
I have a Necchi 537L it was sold as a comercial machine that could do leather. Mine wont do soft paper! Whats up?
This is not a commercial machine and will give you trouble trying to sew upholstery,especially if you use heavy upholstery thread. You will get loops on the bottom.
It will sew only short stitches,No matter how long the stitch length is, because it only feeds the fabric from the bottom and it will stick.
It should sew regular fabric with normal threads with no problems. There is a pressure adjustment on the top of this machine which may be where your problem is located.Look in your book for instructions.Also, make sure the feed dogs are in the highest position. I don't know how long you've had the machine but if it has been awhile,remove the needle plate and clean the lint out from between the feed dog teeth.
sewman7
May 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
126 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
