Question about Toto Home
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Posted on Nov 08, 2010
Tip
What to do if your toilet stops working
When a toilet stops working it can be a major inconvenience. If your toilet isn't working right, try the simple fixes below.
If the toilet doesn't flush:
When you jiggle the handle, nothing happens. Remove the lid from the toilet tank and peek inside. Most likely, either the chain came off at the lift rod or flapper end, or the rod broke in half. If the chain came off the rod, you can simply reattach it. (Finding the right amount of slack will take some trial and error.) Likewise, if it came off of the flapper, it can easily be reattached.
If the lift rod (the arm attached to the handle) is broken, you can purchase a new rod and handle assembly for a few bucks at just about any hardware store. A plastic nut holds the handle into the side of the tank and the whole assembly can be popped out and replaced. Once you've installed the new assembly, reattach the chain.
If the toilet keeps running:
Remove the tank lid and watch the toilet as it flushes. You'll probably see that the chain is too tight, causing the flapper to not close all the way, which results in water continuing to drain out and having to be replenished. Loosen the chain a little and see if it fixes the problem.
Another cause of a constantly-running toilet is an improper float height. The float is the balloon-looking thing that sits on the end of a shaft and falls and then rises when the toilet is flushed. When the float reaches a certain height, the fill valve is closed and the water stops flowing. If your toilet is running longer than it should, push down a tiny bit on the float and see if it stops running. If it does, the float just needs to be adjusted downward a little (by turning the screw at the other end of its shaft). You may need to try a few different heights to determine the optimal position of the float; adjust it slightly and flush the toilet, then adjust it again if necessary.
If there's not enough water pressure:
The chain may be too loose if there isn't enough pressure. With the tank lid off, watch the toilet flush. If there is too much slack in the chain, the flapper may close prematurely, reducing water pressure. Tighten the chain and see if that makes a difference.
Loss of water pressure can also be caused by the holes in the toilet bowl getting clogged up. There are little holes all around the side of the bowl, where water is forced into the bowl to refill it after a flush. If any of these holes get clogged, clean them out with a round file, a nail punch, or a similarly-shaped instrument. (Don't push too hard or hammer on the bowl.)
If the toilet overflows:
If your toilet overflows, the first thing to do is to turn off the water to the toilet. There is a valve on one side of the toilet, where the pipe runs from the wall to the toilet. Turn this valve clockwise to close it.
Once the water is off, use a plunger to try to clear the clog. If it works, you'll see the water drain out of the bowl. If the plunger can't clear it, try a simple drain-cleaning tool like a Zip-It or Turbo Snake. If you don't have anything that can remove the clog, or if the clog remains even after trying to clear it, you'll need to call a plumber (or buy yourself a closet auger or plumber's snake).
If you are able to remove the clog, turn the water back on and flush the toilet to make sure the clog is completely gone.
on Feb 06, 2011 | Plumbing
Water level is set too high and runs over the overflow. how can i adjust the water level in the tank?
Inside the tank, on a lever arm there should be a cylindrical float that rises and lowers with the water level. Attached to the float is a float rod with a clip that can slide up and down the rod. You can adjust the water level by sliding the clip down to reduce the amount of water entering the tank. As the water fills the tank, the float rises, pushing up the float rod, which in turn pushes up the level that controls the valve allowing water to enter the toilet.
Jul 29, 2011 | Kohler K-3515-0 Memoirs Comfort Height...
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
One of our EcoQuantum toilets really doesn't flush. It flushes part way, but only pushing the handle down; it does nothing pushing the handle up. We have to flush several times to get it to work. What do...
Hello
Im Rossouw. qwalifide plumber
Ur problem most likely is ur arm conected to your flush handel.
If the arm is iron, try bending it down so that when u use the handel it has more leverage tolift up ur sistern flush rubber and create a flow facume as we call it.
if its plastick.... u must ajust the hight of ur flush meganisem by turning the head were the arm is conected left and pushing it down and turning it right to fasen it again. this will also work for iron arm bt is un nessesery for iron arm.
ajust hight until problem is solved.
Please rate my advice thanx :]
Jul 02, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
I have a Eljer 150-403 and the toliet will not flush, although the handle is able to be moved down
Remove the tank lid and set it aside. Inside, you should see where tha handle passes into the tank. There should be an arm running along the inside of the tank that raises when the handle is pushed down. Attached to the end of the arm is a chain that goes down into the water and attaches to the flapper valve. Now that you have identified all of these parts, push down on the toilet flush valve, and you should be able to identify where the toilet is broken. It is most likely he flapper or the chain.
Shut the water off behind the toilet, at the wall. Slowly stick your hand into the tank, and raise the flapper. (Don't worry, this is clean water).
Let the water drain through the toilet, and make your repair. All oarts necessary are available at any hardware store. Take your old part with you.
Best regards, --W/D--
Aug 11, 2009 | Home
Home Logo
1,334 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
