We have a Sanyo ProxtraX multiverse projector. We have used it a number of times but recently, it will not see the laptop. It turns on but cannot find the laptop signal. I have tried different laptops and different VGA cables (no DVI input) but nothing works. Any suggestions? Thank you!
    Novelist:
    Champion:
  • 225 Answers
Have you tried the "Function and F key" trick? On most laptops it's the F6 key but on your unit look for a picture/graphic of a computer screen...or maybe text saying, "LCD/Monitor". To activate this function you must press and hold down the blue "function" key and also press the F6.
The F6 key has three states...1 - only laptop screen, 2 - only external monitor (video projector), 3 - both the laptop screen and the externally connected monitor and/or video projector.
Posted on Nov 08, 2010
  • christi330 Nov 08, 2010
    i have tried the Fn keys and all of the options allowed. I've also tried other projectors and a brand new VGA cable. I've tried turning the laptop on first and projector on first...all the tricks I've always tried but this one isn't responding. is it possible that the VGA jack is bad? Is that replaceable?
  • Glen
    Glen Nov 17, 2010
    From the "process of elimination" that you're doing it does sound like the problem is with the projector and/or VGA input port. If you have access to another LCD projector try connecting the normal laptop and VGA cable config. as a final test. If it works on another LCD projector that only leaves the Sanyo input/menu settings or the actual VGA input circuitry.
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
I cant see my computer images on my projector
Assuming you are running windows 7: if you go into your control panel there is a menu for adding a display device, you want to choose connect to external display, when you get into that menu, there should be a dropdown where your computer will have auto detected the projector, select your projector from the list, then just below that I believe you want to choose the option to duplicate on both screens. Sorry if this isn't clear enough, but I'm on my older computer still running XP and I still havent been able to figure out how to use multiple display devices with this OS.
Aug 29, 2012 | Sanyo Proxtrax Multiverse Projector...
Can you connect a Mac ProBook laptop to a ProxTrax Multiverse?
Hello. There is no "device" needed to connect the units together...You'll need a cable that is"mini display port to vga". In order to connect the projector to the laptop, the cable has to have the special Apple connector which fits into a specific socket on the back of the laptop. The other end is just a standard vga connector which is plugged into the computer input on the projector. Hope I helped you!
Aug 20, 2009 | Sanyo PLC XU35 Multimedia Projector
No Signal
1. check cable make sure there is not bent pins on ether end.
2. check device with another computer if you get signal from other computer it may have to do with the computer your hooking it up to.
3. you can also try to in windows go to your video card properties and click on the secound display icon and activate the secound display.
Good luck please do not shoot the messanger and leave a good rating, thanks for using fixya.com
Aug 12, 2009 | Sanyo PLC XU35 Multimedia Projector
No light being projected from unit,
I will guess that your lamp is dead, buy a new lamp.
And if u want to buy a lamp to the lowest price u can get, buy it from www.pricejapan.com
Good luck
Dec 01, 2008 | Sanyo PLV 70 Multimedia Projector
Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo LCD Projector
Hi smnheffernan
If there is no LED's switching on , then you can definitely rule out the lamp.
Try opening up the unit by taking out all the screws at the bottom and taking of the top cover.
Then repalce the fuse that is on the Powersupply Board ( the one that has the AC socket on it )
If the problem there after still exists , you will have to replace the Powersupply Board.
Hope this is of help and thanks for using Fixya !
May 05, 2008 | Sanyo PLC XU35 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
269 people viewed this question
jasbo
jasbo
