Question about Harman Kardon HD750 CD Player
My cd player will load , but the display will not register the cd details and it will not play. You can hear a soft rotating and clicking noise, but no sound will come out. For a while it would do this off and on, now this is all it will do. I have tried a cleaning disc and this got it working for a while but it will not get it working any more. Is this something that can be repaired, or do I need to purchase something more up to date (it is 20 years old but very well cared for and I have enjoyed the sound quality)?
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
I have a 2004 Mazda 3 w/ a single disc CD player...which has not been working for several months. There is a cd in the player but nothing happens when I press the eject button nor the CD button; won't...
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
May 03, 2011 | 2004 Mazda 3
"No Disk" message on front display
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Dec 27, 2008 | Pioneer DV-343 DVD Player
When playing cd player , cd rotates angle of 5 degrees clockwise
Hi there
It is probable that you will have a faulty spindle motor if the disc wont spin up to speed. Have you been able to give the disc a kick start to get it to read. The disk also has to spin the fastest when reading the table of contents after the disc is first loaded. Sometimes when the suspension rubbers to the laser fail, the disc may also be catching on parts of the mechanism preventing it from spinning up to speed. Can you give me a little more about how the problem is occurring, particularly what noises you hear, and whether you can kick start the disc to spin. I have plenty of experience repairing these players, and am happy to answer any questions you may have about it. Cheers
regards
robotek
Dec 11, 2008 | Pioneer Audio Players & Recorders
Colby dvd/cd player
dvd will not play. when I push play button, nothing happens. the red light is on showing it is plugged in, but nothing moves.
Aug 09, 2008 | Televison & Video
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Apr 12, 2008 | Polaroid PDV-0813A
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Nov 28, 2007 | Classic Electronics CDR201 CD Recorder
Harman Kardon HD750 CD Player Logo
54 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
