Question about GE Spectra JBP84SHSS Electric Kitchen Range
Convection fan quit - GE Spectra JBP84SHSS Electric Kitchen Range
  • kbsiders Nov 09, 2010
    Besides replacement, is there another option, or a way to confirm that's the issue.
    I appreciate the help. Your answer was really thorough.
  • GE Master
  • 1,711 Answers
If you want to confirm that the fan motor is bad then you can use the meter to the two wire terminal of the motor to see if you have a voltage if yes then motor is bad, if you don't have voltage then the problem is with control board. However the most possible is the motor which is usually bad.
Here below is the link with your range parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5215289
Posted on Nov 09, 2010
    President:
  • 2,777 Answers
Ok, it can be replaced for sure...Is this a GE JBP84SHSS as indicated?
Please let me know and I can find the replacement convection fan for you..
Just reply to my answer here and I can help.
Thanks,
Tim
Posted on Nov 08, 2010
  • Tim Grayson
    Tim Grayson Nov 09, 2010
    Wish we could have worked on this more, but that's alright.
    Tim
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
I need the manual of my haas microwave oven HMW 43 W I want to know can i bake in my oven or not
m/w do not bake they heat up water molecules in the items that you put in them . unless it is a m/w, convection oven that has a heating element and a convection fan in addition to m/w components in it usually a metal fan visible protruding from back of inside the cavity. also m/w , convection ovens are ether over the range or together with convection oven in the wall combos and cost quite a bit more then counter top. $250 +
Jan 22, 2015 | In Microwave Ovens
My hamilton beach mod 31197S convection fan quit working. Is it worth fixing?
See my ongoing post here:
http://www.fixya.com/support/t8640984-fix_fan_in_hamilton_beach_31197c
Not an easy repair, but possible. Depends on whether only the bearings are seized or you have a shot winding. HB will not sell any mechanical/electrical parts and if they did, the price would probably be more than a new oven.
Dec 06, 2010 | Hamilton Beach 31197 120 Watts Toaster...
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Clicking noise of fan on convection
The motor on the fan has to be replaced.The fan is hitting the screen .Hopfully that will fix it .Thank you .
Nov 05, 2008 | Sharp R-1850A Convection/Microwave Oven
Convection fan
This is caused by a faulty wiring connector. It is a gray iec type connector there will be 8 wirs connected on each side of it. You can get a replacement from blodgett directly. Or what I have done is to eliminate the block using solderless **** connectors.
Aug 06, 2008 | Blodgett (ZEPHAIREG-DOUB) Double Oven
GE Spectra JBP84SHSS Electric Kitchen Range Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
