Question about Husqvarna Chain Saw Handle Models 362 365 371 372xp
The saw wont start up - Husqvarna Chain Saw Handle Models 362 365 371 372xp
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Make sure there is fresh fuel mix in the tank and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Remove the spark plug and check for blue, snappy spark (plug gapped 0.020"). If weak or none, try a fresh plug. If no help, remove the left side cover to expose the flywheel and ignition module. Remove the ignition switch wire from the module coil and try for spark again. If still nothing, try setting the module pole gap by turning the flywheel magnets under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps don't close up at any point. Recheck for spark--if still nothing, replace the module using the above procedure. Assuming that the engine has good compression and the carburetor in not in trouble, it should start. Hope this helps!
Posted on Nov 09, 2010
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
Won't start when motor is warm. Saw for half hour and shut it off and it refuses to start again
this sure sounds as if it's an overheating problem , this causes the ign ckt to over heat and shut off the spark at the plug , id get a real good look at the cooling fins and make double sure theres no sawdust or other stuff in there blocking up the works , if you continue to run saw to overheat eventually it will damage the ign ckt to the point it wont come back on and saw wont run ,Period.
I use strong compressed air to blow out stuff stuck down in the ribs of saws(wear glasses )
Aug 06, 2015 | Husqvarna 550 XP 50.1cc 16 in. Autotune...
Table saw starts for 2 second and stops
if it is electrical u might wont to check the battery if it is gas u might wont to chek the oil or the gas if it is gas
Jun 03, 2013 | Makita 2703 10" Table Saw, Electric Brake
Tile saw wont start. It's brand new. Is there some sort of safety device.
The first thing you should check is the GFCI switch on the power cord. All tile saws have one because of the water involved with cutting tile. It should have a test and reset button on it, press the reset button to get power to the saw motor. Some bigger saws also have a reset button on the motor itself for overload issues. Check for that if the GFCI reset doesn't work.
Jun 02, 2012 | Saws
18"poulan chain saw wont rev up
carbs dirty need cleaning. try adding some stabil you can buy at auto zone with fresh fuel it may clean itself out w/o having to remove the carb.
Sep 14, 2009 | Poulan PP4218AV 18" Chain Saw
My chain saw wont start just changed the magneto and still wont start
IF YOU ARE GETTING FIRE TO PLUG TRY A SHOT OF STARTING FLUID IN AIR BREATHER BE SURPRISED HOW MANY IT WORKS ON
Nov 26, 2008 | Poulan Pro Chain Saw 46cc 20"
Husqvarna Chain Saw Handle  Models 362 365 371 372xp Logo
252 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
