Question about Car Audio & Video
I have a 2000 pontiac bonneville. i was told to push the hrs and mins button. nothing still isn't happening. i have an appt tomorrow for technical suppport. is it necessary if u can help me?
  • 23 Answers
What is the problem that you're experiencing?
Posted on Nov 08, 2010
2000 bonneville brake,antilockand trac off lights are on.
Did anyone put a scanner on it? Could be the fuse, a bad ground, the ABS pump, or the ABS module. some times wiring.
Mar 31, 2015 | 2000 Pontiac Bonneville
Electric window will not go up on a 2000 bonneville
If you can hear the motor running when you push the button, you have a broken window regulator. If NOTHING happens when you push the button, the problem needs to be properly didgnosed to find the cause.
May 02, 2012 | 2000 Pontiac Bonneville
I have a 2000 pontiac Bonneville sle and it was running fine it stalled yesterday on me n after a bit started back up and ran fine the rest of the night, This morning It started fine and then 15 mins...
I had the same problem with my 2000 Bonneville SLE and I replaced the crank shaft sensor and it solved the problem. The crank shaft sensor is located behind the harmonic balancer. You have to take the balancer off to get to the part. You will need a puller to get it off. You will also have to take the fly wheel cover off and hold the fly wheel when you remove the nut from the front of balancer.
Jun 14, 2011 | 2000 Pontiac Bonneville
I have a 2000 Pontiac Bonneville my air blows hot air out on my driver side and cold on the passanger side. Iv set the Temp on both side to 60 and nothing changes it
Sounds as if the door actuator has quit working on the driver's side. this is a very difficult unit to access and should be done with courage or by an expert "groan" dealer.
Apr 10, 2011 | 2000 Pontiac Bonneville
2001 pontiac bonneville SSEi 3.8 l supercharged. The car runs smooth for 15-30 min then stalls out. And when you attempt to restart it starts and idles up and down. And dies after 30 sec. With no check...
I have a 2000 Bonneville - I had a problem with the car stalling out - then it did not want to start back up. (When it did it would idle up and down and then die) I changed out the mass air flow sensor - now I have not had a problem. Good luck with it.
Feb 10, 2010 | 2001 Pontiac Bonneville
Keyless entry did not work
If I am not mistaken, this is a safety feature. You manually locked the doors which told the computer you could possibly be in danger and someone on the outside has your key. After you unlocked and started the vehicle it reset the mode and that is why it works now without a problem. You can test this by manually locking it again and trying the keyless entry. If it does not work, then unlock and start the vehicle and try again. If it does work have the dealer check it out as it could be the receiver for the keyless system.
Sep 30, 2009 | 2004 Land Rover LR3
2003 Bonneville SSEI
I am having the same problem and also occasionally the cruise just shuts off when I am driving on dry, straight roads. Code C1288 was cleared, but it continues to happen. I was told that the electric brake module needs to be reprogrammed and that it will cost about $80.00. They are still looking into it.
Apr 26, 2009 | 2003 Pontiac Bonneville
I need to reset the clock
with the ignition in the on position not running radio power off there should be a set button on radio push and hold while holding it on push seek button for hour then scan button for mins. or vice versa
Mar 21, 2009 | 1992 Pontiac Bonneville
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
