Question about Meade LX200GPS Telescope
My telescope does not pick up gps signals i get a message on the hand controller saying the sensors can not detect home postion. how much wouuld this cost to repair
  • 3,186 Answers
Could just be a DEAD battery-- check the manual and replace the battery. If this does not work then it may need to be sent back to Meade for repair:
Here:
http://www.meade.com/support/index.html
Posted on Nov 10, 2010
Why doesn't the GPS pick up a current GPS signal?
You may need to do it outdoors; a building may interrupt enough satellite signal that it (the GPS) won't lock to it (the signal).
If it always says "GPS SIGNAL NOT DETECTED" when it's outdoors, I don't think you're going to get it to ever work. It may have been dropped & the internal antenna damaged.
Jul 26, 2014 | InVion GPS
Tip
ERROR codes Canon 8580
Canon 8580 E000 The temperature of the upper fixing roller has not increased above the specified level 90 seconds after switching power on. The temperature of the upper fixing roller does not reach 150 C within 8 minutes after switching power ON. The temperature of the upper fixing roller does not reach 180 C within 5 minutes of reaching 150 C. The temperature of the upper fixing roller drops below 50 C during STANDBY. E001 The temperature of the upper fixing roller exceeds 250 C. E005 The length of fixing assembly cleaning belt wound on the take-up reel exceeds the specified length. E010 When two or more clock pulses are not inputted for a period of 2 seconds after a MAIN MOTOR DRIVE command is generated. E011 When excessive current is detected by the fault detection circuit of the DC driver PCB. When excessive current is detected by the fault detection circuit of the duplexing unit driver PCB. When excessive current is detected by the fault detection circuit of the scanner motor driver PCB. E020 When a toner out signal (TSP) is emitted from the developing assembly for a total of at least two minutes. E050 When the HOLDING TRAY HOME POSITION signal (THP) is not generated within 4 seconds from the beginning of HOLDING TRAY MOTOR DRIVE command (TMDP1,2) When the HOLDING TRAY HOME POSITION signal (THP) is generated for at least one second while the HOLDING TRAY MOTOR DRIVE command (TMDSP1,2) is being generated. E203 When two or more clock pulses are not inputted from the SCANNER MOTOR DRIVE command is being generated. E210 When the LENS HOME POSITION signal (LHP) is not generated within 4.8 seconds after the power switch or door switch goes ON. When the LENS HOME POSITION signal (LHP) is generated for 2 seconds or more. E243 When an abnormally in communication occurs between the microprocessors on the DC controller PCB and those on the control panel PCB. E400 When an abnormality in communication occurs between the DC controller PCB detect RDF controller PCB. E401 When a flag mounted on the pick-up roller HOME position sensor (S3), it indicates that M1 is turning. S3 should go ON and OFF two or more times in one second. E402 The number of pulses in a 200 ms period is too low. E403 When the number of feed motor clock pulses in a 200 ms period is less than the correct value. E411 When the sensor output is greater than 2.3V when there is paper. E500 When an abnormality in communication occurs between the DC controller PCB of sorter detect main controller PCB. E510 When there is no pulse output from the feed roller motor and when the first copy jams. E540 The lead can HOME position sensor does not go "OFF" within 0.5 second after the BIN MOTOR DRIVE signal (BMON) is output. E541 The lead can HOME position sensor does not go "ON" within 1.0 second after the lead cam position sensor goes "OFF".
on Jan 19, 2010 | Office Equipment & Supplies
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
2000 galantwhat is codep0715
P0715 MITSUBISHI - Input/Turbine Speed Sensor Circuit Malfunctionpdf.gif? comments.gif ' Add Commentxicon.jpghttp://engine-codes.com/p0715_mitsubishi.htmlForum CodePossible causes - Transmission speed sensor circuit is open or shorted
- Transmission speed sensor circuit poor electrical connection
- Faulty transmission speed sensor
help.png Help with thisWhen is the code detected?Diagnostic Trouble Code (DTC) P0715 is detected when TCM or ECM does not receive the proper signal from the sensor.Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Possible shifting problemsP0715 MITSUBISHI Description The input speed sensor detects the primary pulley revolution speed and sends a signal to the Transmission Control Module (TCM) and Engine Control Module (ECM).
Need more help?Do you need more help with the P0715 MITSUBISHI code? ask a question to our users or search the top hand picked automotive forums for more information
Read more: http://engine-codes.com/p0715_mitsubishi.html#ixzz2QYRb9Yyu
Follow us: EngineCodes on Facebook
Apr 14, 2013 | 2006 Honda Accord
Is there a list for computer codes for 1980-1990's Chrysler Le Baron
Yes here is that list.
Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
Part 1: Chrysler Domestic vehicles
CODES/Meaning
88 display used for start or test
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle positioner sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 wastegate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects overboost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eeprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
May 31, 2011 | Chrysler LeBaron Cars & Trucks
I am using an LX 200 GPS gimbal with no autostar control hand box. I want to be able to talk to it using my Autostar Suite and a computer. I have the USB to RS 232 cable and the connector to go from the...
1. Plug the cable into the BOTTOM of the hand controller-- NOT into the control panel.
2. Set the software to the proper COM port. Look under Telescope in the dropdown tab.
Feb 18, 2011 | Meade LX200GPS Telescope
I have an older Meade LX200 GPS with autostar II handset. The telescope was working fine and last night I got an error message on the handset "Error: Inv. Heap" and the telescope locks up with no further...
You may have Corrupted firmware in the hand controller- that's why they want you to do a RESET.
You might have to reload the correct firmware to fix this problem.
I believe if you hold down the ENTER KEY and the SCROLL DOWN arrow key and then turn on the scope you enter SAFE LOAD where you can reload the firmware.
Sep 02, 2010 | Meade Optics
Inability for the telescope align
Replace the battery for the GPS.
Start from scratch.
Reset the hand controller, calibrate motors, train drives, calibrate sensors.
Make sure you have either fresh batteries, or better a seperate 12 volt power pack. The above will eleiminate everything except an actual BROKEN electronic part (such as a bad gps board).
If it still will not align using the gps, time to send it back to Meade for repairs. Make sure you have the latest firmware in the hand controller which is 43Eg. You can download the firmware using the UPDATER free software here:
http://www.meade.com/support/downloads.html
May 08, 2010 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
Meade 14'' LX 200 GPS telescope
If it will not boot-up it's probably the main board. However, I would try a brand new hand controller cable first before I panic.
A fellow by the name of Ron Sampson can repair the hand controller and or the main board circuits. He can be contacted by placing a message for him on the LX200 and the LX90 Yahoo Tech Group.
Hope that helps you. You can send him the hand controller and the main board and he will have a look at it.
Apr 20, 2010 | Meade LX200GPS Telescope
Wont pick up a signal.
Try updating with the latest GPSfix updating via the tomtom home software
Aug 01, 2009 | Tomtom XL 330S GPS Receiver
Meade LX200GPS Telescope Logo
70 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
