Question about Estate TEDX640JQ Electric Dryer
The dryer stoped working. - Estate TEDX640JQ Electric Dryer
  • Estate Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Dryer stoped "heating up" the
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Dryers
My dryer stoped working. I replaced the push to
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63952 Electric Dryer
My dryer does stoped and it does not start again
look for a blown DUCT FUSE
Failure to remove air restrictions will reult in continued problems. Tumble dryers have 2 small limits in the rear and another on the heater element. Tilt the dryer over and remove the base to clean out the fluff. American dryer repair photos HERE
Feb 16, 2010 | Dryers
My dryer just stopeed heating.
You will want to check the thermostat first. If it is blown, ther is a chance that the thermal cut-off is gone, too. Also, do a continuity test on the heating element to see if there is current getting through the element.
Jan 24, 2010 | Kenmore Dryers
Stoped working
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
May 30, 2009 | Miele Dryers
Hotpoint Dryer Heat stoped working
Loook inside door an get me the model number. The heat thermistat and the high limit switch will possibly need replaced. Enter the model and part numbers in the search feature on my site below. We offer free help and assiatance also. Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Hotpoint Dryers
Intermittent ignition
my dryer just stoped. when i press the start button it makes a noise and then theirs a small burnig smell if i turn the tumbler it works for awile then back to the dryer being stoped again.
Dec 09, 2007 | Whirlpool LGR8648 Gas Dryer
Estate TEDX640JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
