Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hello. I have a Magnavox 42MF531D/37B Flat Panel Television. My uncle gave it to me, because he says the power won't come on and i was wondering if that's a problem i can fix myself?
  • 144 Answers
I would have to say probably not. If you have no power at all (no stand by light) then I would suspect a blown fuse , check plug , If you havestand by light nothing else i would think capacitors in power supply are leaky. Capacitors are cheap , easy to replace but not for a novice, Capacitors usually swell up when old and can easilly be spotted to the trained eye.
have your local tv guy estimate repair
pete
Posted on Nov 08, 2010
TURN ON PROBLEMS AND SOLUCIONS
If a buzz or such and it seems to come from the power board its a transformer or coil vibrating hard enough to make the sound--not a uncommon issue.
Dec 06, 2012 | Philips 42MF531D 42 in. LCD Television
Magnavox tv won't turn on or off
The typical cause of power up problems in a failure of the power supply filter capacitors. The board can be repaired by replacing the bad components. Below is a picture of the power supply board with the bad capacitors circled and below that is a link to a it that is available with the correct parts to rebuild that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=216
I hope this helps you out,
BuddyMc
Sep 25, 2012 | Toymax Magnavox 37MF331D 37 in. LCD TV
The power light on my Magnavox 42mf531d 37 flashes green
Download its service manual from internet. It will have all details with illustration.
Sep 16, 2012 | Televison & Video
I Have a Magnavox 42MF531D with no picture and when it is plug in, I hear a chirpping sound.
Problem will be either in power supply circuit board or something loading power supply down.
Someone first would need to test voltages in and out of the power supply to see what is wrong.
sj
Sep 28, 2011 | Philips Magnavox 51MP392H Rear Projection...
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Vertical shadow on screen
check the vertical transistor or bouton.
Nov 16, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox 42MF531D black screen
Common issue I have come across when using any TV as a PC monitor. Best workaround i found is just dont change inputs or reboot the PC and the tv will pick it back up.
Sep 01, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Screen goes out but sound remains
A blown fuse would not be intermittant.
It is possible that the back plane lamps, and or the back plane power supply is failing.
When the set is in the dark screen, shine a flashlight on the screen at an offset angle. Look carefully and see if you see the picture images. If so, this proves that the back plane lighting is having a fault condition. If there is no image at all, then there may be a fault condition with one of the drive boards for the picture processing or the screen itself.
Jerry G.
May 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
201 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
