Question about Dryers
GE Gas Dryer
Glow light comes on, but gas valve will not light. Everything else seems to be working.
Thanks
    President:
  • 2,712 Answers
Please read this article for detailed info:
http://fixitnow.com/wp/2004/11/30/appliance-repair-revelation-burner-operation-in-a-gas-dryer/
and
http://fixitnow.com/wp/2004/09/19/appliance-repair-revelation-troubleshooting-a-gas-oven-that-wont-fire-up/
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Jun 16, 2008
DPGT750Gc1ww Wont heat up Igniter lights but burner wont light
If it's an HSI (hot surface ignitor) that glows, then usually the ignition control module looks at it's current draw, to assume that it's hot enough to ignite the gas. If the current draw isn't sufficient, then it won't open the gas valve.
If you see it glow, put your volt meter on the gas valve terminals to see if it gets energized. If it doesn't energize before it locks out, then let the HSI cool down to room temp and check the resistance of it. Compare that resistance reading to a new one (one that is worn will have a higher resistance than a new one - more resistance, less current draw!).
Feb 22, 2015 | GE Profile Harmony DPGT750GC Gas Dryer
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
I have a GE gas dryer DBVH512GF1WW. The heat is inconsistent. I noticed the ignitor glowing and then a flame shortly after on the initial time I turned the dryer on. Then after the flame going out after...
sounds like bad gas coils located on top of the gas valve,when the coils start to fail the ignitor will glow,the coils let the gas in until the coils heat up and then ignitor glows but no gas.when the coils cool down they might work again for a short time until they heat up and fail again.if the flame lights and goes out after like 30 seconds and goes out and keeps doing this you have a block either in the dryer or the vent line but it sounds like you have bad gas coils.unplug the dryer,get at the valve,pull off the wires going to the coils and check them with a meter,one should be open,just remove the two phillips screws pull off the cover and slide the coils up off of the posts,unplug them and put the new coils on,you'll see like a little piece of plastic on the top of the coils,this fits intoo the cover so they line up correctly and holds them in place,also on the larger coil there's a spacer on the post,if you don't see it look inside the old coil,poke out the spacer and slide it onto the post and then install the coil.
Oct 23, 2013 | GE Dryers
I have a MD7600 maytag dryer. It runs but it will
when you turn it on give it a few minutes and see if you see a glow. that will be the ingnitor.if glowes low or dont see a glow at all then id say you have a bad ignitor. if you see a bright orange glow then id say your gas valve is bad. the ignitor is located next to the gas valve, usually their is a peep hole in the front of the dryer that you pop off (dime size cap) and you can look in hole and see if you see a glow. ignitor price roughly 20-50 dollars. vale can be pricey. 50-145.00 dollars part only. labor ingnitor 75-125 and for valve 85-165 depending on were you live and who you use. usually one or the other not both and seldom a thermostat could be bad.
Sep 17, 2009 | Maytag Dryers
Gas dryer - kenmore 110.73932102
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | Frigidaire FDE336RE Dryer
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Gas dryer will only light one time glow plug comes on but no gas
Replace the gas valve coils. When they get hot, they are going out on overload.
May 22, 2009 | GE Dryers
Glow coil lights...but gas valve seems to be stuck.....tests from here?
If you are sure that your model is a Whirlpool LGR5636L gas dryer I can help you. But before we begin look inside the door on side of the door opening and send me (those numbers). Thanks, Sea Breeze seabreezehvac@yahoo.com
May 10, 2009 | Whirlpool LGR5636L Gas Dryer
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
107 people viewed this question
Top Dryers Experts
