Ive a problem with the volume of the headphones, the right one works fine but there is no sound from the left side....ive tested the headphones on other electronic equipment and the headphones work the best.....think it may be a problem with the settings of the ipod nano, just cant figure out how to fix it, need assistance asap
  • 425 Answers
Hi,,in most cases what causes one side of the headphone to work is because, the wire that is connected to speaker inside the headphone might have cut and it's not contacting properly.
What you will need to do is to open up the head phone (left),and check if the wire inside has not cut, If it has removed ,then you will need to put it back with soldering iron and a lead...
But if the wire inside has not removed and they are intact, then you will have to replace the left speaker .
Hope that helps...
Thanks for using fixya...
Posted on Nov 08, 2010
    Novelist:
    Champion:
  • 225 Answers
It sounds like your audio player may have the left, right "balance" control setting adjusted to ONLY right. Also check any headphone adapter(s) that you may be using with the "no left audio" unit but not with "both sides working OK" devices.
It may also be the 3.5mm audio jack which is soldered straight to the printed circuit board and often gets broken connections from rough headphone plug abuse.
Enable the microphone on a toshiba equium
you need to get a mic / headset
ive even found them in the £1 shop
and they work aok
on the front of the equium is wo sockets and a small volume rotory control
place the green plug into he headphone socket
and the other plug into the mic input socket
the equium doesnt have a built in mic
so you need to do this
once this is done you can open the volume control {task bar} or the realtek applet in the control panel
or .. just the windows sound applet
fine the mic input section and check its not muted
you can use skype echo test to make the levels good and test it out
windows all also allow you too do this
my advice with the equium and XP is too go to the realtek site and download the AC97 driver from there
it works better
ive retired my equium now but it still works fine and i enjoyed writing over 2GB of code and projects on it ..
good old equium
Dec 05, 2014 | Toshiba Computers & Internet
Left side of headphones not working
Hello if you think that you can do follow this link,you just need to do is to apply jumper.it is indicated in the image clearly Nokia 5800 Handsfree solution.Good luck
Jun 26, 2012 | Nokia 5800 XpressMusic Smartphone
Very low volume
Change your audio settings to headphones :)
Mar 08, 2010 | Skull Candy Lowrider Headphones
Mic dont work help i checked the wire and volume and it still doesnt work. ive been using windows media to play the video but there is no sound
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Feb 18, 2010 | Gear Head WC330I Webcam
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
Sound louder in right Ear!
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Feb 09, 2009 | Itech Blue Pro Bluetooth Stereo Headphones...
Cant hear songs
It sounds like your headphone/hold cable is faulty. Try plugging it into a sound device with a docking bay. If no sound comes out of there either then it's a faulty logic board.
Nov 19, 2008 | Apple iPod MA446LL/A MP3 Player
No Volume
The earphones input are in bad conditions you need to change it,or try put in the earphones and put out until the picture of the earphones go out.
Aug 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Jun 17, 2008 | Insignia Bluetooth Wireless...
1,523 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
