Question about Sony Walkman TCD-D8 Personal Cassette Player
Hello. My Sony TCDD8 Dat Recorder is missing the DC power adaptor and the battery case holder assembly (holder is inside the compartment). I would like to know if you know the part numbers for these items and where I might locate a source for these two items? Thank you, Elizabeth
  • 4 Answers
Use any power supply with the correct voltage and polarity and tip size.
Posted on Oct 27, 2011
How many volts is the power adapter
The speakers use a 10 Watt power supply
Sep 06, 2011 | Sony SRS-A37 Computer Speakers
Difficulty Recharging Battery
You need to change the battery, not the adapter
Mar 22, 2008 | Mintek MDP-1060 10.2-in 16:9 Portable...
Power on problem
hello my friend,
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
hope it will help you today.
Aug 30, 2011 | Computers & Internet
I get a pop up note that the power supply in insufficent, and then the computer shuts off. Other times it works fine.
The message you are getting is telling you the battery is discharged, UNLESS you are plugged into the mains, in that case, the battery is not charging and the adaptor is not supplyig power to the laptop.
You may have a faulty charging circuit, a loose connection from the DC jack to the DC socket on the laptop, or a failing adaptor.
Check the above and repost if not solved
Jan 29, 2011 | Compaq Computers & Internet
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
Missing The Power Adaptor for the Mod. BEFSR81B
HI Salvador, the specs for the power supply of the BEFSR81 are:
Voltage: 5V DC
Ampere: 3A
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 16, 2009 | Linksys EtherFast Cable/DSL Router
What is the ac adaptorfor sdr-h40
It's the little black box that's got "Panasonic AC Adaptor" written on it. It looks a little like a power brick, but you can put a battery into there. (You also need to plug in the DC power cord, which goes into the same compartment on the camera as the battery does. It looks like a battery with a cord.) Hope this helps.
Jul 11, 2009 | Panasonic SDR-H40 HDD Camcorder
Battery change
The battery is housed in the xlr adaptor DC-78. You may need to unscrew the barrell about the outside of it to replace the batt.
Or alternatively use phantom power to run up the mic(this is easiest
. Be sure to connect it to a channel that is phantom power optioned
Here is the spec sheets for it with details of the adaptor you need and battery type required.
http://bssc.sel.sony.com/BroadcastandBusiness/docs/brochures/ecm44b%20brochure.pdf
Good luck
Jan 27, 2008 | Sony ECM-77 Professional Microphone
Sony Walkman TCD-D8 Personal Cassette Player Logo
289 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
