Question about Microsoft Xbox 360 Console
Unclear picture, frame keeps going up & down, TV fine possible loose connetion ?
  • 43 Answers
If this happens alot it is most likely to be your av leads. What you should do is try borrowing someone's av cord and see if it does the same thing as it may be that your xbox is faulty. If is still doing it then take it into a game store/ fixer man and get them to try and they might replace the consle. =] Hope it helps.
Posted on Nov 09, 2010
Hello, I have Samsung TV Model: UN60ES8000FXZA. I replaced the Main board, TV works fine, except the upside down picture. How to fix this problem, I need to get special codes.The same picture on the M
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 31, 2015 | Samsung Televison & Video
On initial turn on, my Sharp 55R rear projection tv is in color but switches to black and white after a few minutes. Prior to going BW the picture is HD and all other functions of the TV work fine....
There is only a loosed or cold solder in the main pcb of your tv in order to fix this you should have a soldering iron, lead, and desoldering pump.Try to remove the back cover of your tv but be sure to unplug the unit before opening it, then try to pull out the mainboard of your tv but be carefull because some of the connector may accidentally remove and observe the solder part of the pcb, using a magnifying glass is much beter to locate the loosed solder.But when doing some soldering in the pcb be sure not to solder separate pin if accidentaly conneted it may cause much problm to the unit or you can try to contact a service technician to do it for and save from stress good day and best regard.
Aug 20, 2011 | Sharp 55R-WP4H 55" Rear Projection...
I have a Lg 42" lcd tv (42LG3000) TV is wall
White screen with good audio. before buying pcbs & such. try my repair method.. you need to get the lcd unit off the facia & then remove the front lcd metal frame. at the top of the screen you have 2 thin pcbs - chances are that the ribbon cable got at least one track unbonded. first off put some double sided tape under the pcbs to stick then to the frame - that'll take the bend out of those pcbs !! next put cellotape over the ribbon cables. i then cut 6 pieces of sponge 15mm thick & wide as the ribbon cable & glue to the tape on the ribbon at what would be the top edge of the screen (covering the point where ribbon meets pcb).. put the metal frame on top edge first to keep the sponge straight !! put it back together & fire it up. if it still aint working you may need a tcon pcb (little square one at the top). this fixed my 42lg3000 but can work on others with same fault !!
Mar 16, 2011 | LG 42LC2D 42 in. LCD HDTV
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Kodak EasyShare EX1011 Digital Picture Frame
Probably a loose cable or a problem with the circuits
Oct 18, 2009 | Kodak EasyShare EX1011 Digital Picture...
3-d look on words and unclear picture
Go to convergence in the menu. If you colors will not move you need convergence amps. Have professional install
Apr 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
DLP TV keeps flickering
Please recheck component connections in both units and make sure to hook up them according to corresponding colors like blue to blue, red to red and orange to orange.
Dec 13, 2008 | Samsung HLN5065W 50" Rear Projection...
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
