Question about Dishwashers
Our Matsui MF160 will not stop beeping. When you put the power on it beeps continuously. It comes on and hums but doesn't start, no water comes out. The Salt and Rinse Aid lights were on at the beginning but we have filled both of them, the lights are now off, but the beeping continues?? Can you help?
IFIXALL
  • 868 Answers
SOURCE: hi just had new dishwasher
Rinse aid is always needed for ALL dishwashers to properly operate.
Posted on May 26, 2008
abhishek33
  • 1239 Answers
SOURCE: matsui mf160 deturgnt door wont open
hi The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent the door will not open
Posted on Sep 13, 2008
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Posted on May 12, 2009
SOURCE: Matsui MF145 beeping continuously
You might want to check the salt and rinse levels on your dishwasher.
Ours was doing the exact same thing and we refilled the dishwasher salt and it worked again. Unscrew the plastic thing on the bottom of the dishwasher and fill it up with about 1 kilo of dishwasher salt, water will flow out when you do this and you can put at least 2 kilos in.
Hope that helps xxx
Posted on Oct 19, 2009
  • 120 Answers
SOURCE: matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Posted on Nov 02, 2009
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Matsui mf160 beeping then stops and wont select programme
I had the same problem today. The good news is I fixed it without replacing any parts. I tried a few things which may have worked so I will list them all. I'm not sure which one worked so try the easy ones first.
Fill the salt and rinse aid depensers up.
Once it starts beeping continously close the door and let it drain itself. Do this several times. Turn it off and leave it for a minute between goes. With the power button light on leave the door open slightly for about 15minutes, mine beeped after about 7 minutes and it had reset itself.
At the bottom of the dishwasher underneath there is an anti flood switch. My tray had water in it and caused the float to rise up and activate the switch which stops it from working. Easiest way to drain it is to pull the dishwasher out put down a load of towels and tip it backwards until all the water is gone. I found it easier to check for water through the right handside side panel, it comes off pretty handy. I also removed the upper front cover to check the door catch switch. Just make sure its not broken and not wore down etc. I also sprayed it lightly with WD40. Try disconnecting the wated inlet pipe at the back once you have turned the water off. Mine had a lot of pressure in it which it should probably should have but read somewhere else it solved their issue. I then stripped both sides off laid the machine on its back, make sure to disconnect the water inlet pipe and took apart the drain pump. If your looking at the back its on the right hand side, mine was dark grey and was attached by two screws to the side panel. There is 4 or 5 screws which hold the drain pump together. Unscrew these and again there will be a build up of pressure and water released. There might be a foreign object stuck in here which will stop the blades turning. Check the espares youtube channel on how to remove this, thats what I did. After all this mine didnt work straight away and I had given up. But I left the power on with the door open slightly and after 7 minutes it beeped and I was able to select a program as normal. Maybe the turning over on its back and release did the trick Im not sure but give it a go. Good luck
Jan 18, 2013 | Dishwashers
Matsui mf160 starts its wash cycle and timer stops
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Matsui mf160 deturgnt door wont open
Sep 13, 2008 | Dishwashers
Matsui dishwasher mf160
I used the solution I found for a slightly different fault, ( this was the same fault but without the bleebs)
switch off mains and turn off water. Then disconnect water pipe and lay machine on it's back. Switch on electrics, and allow water to run out. Switch off electrics and stand machine up .Reconnect everything and hey presto I can hear two good things, the machine gently humming, and my wife telling me what a genius I am !!
Aug 05, 2008 | Electronics - Others
Matsui MF160 Dishwasher
Unplug the cable and wait for about 15min. and then plug in cable back and turn on.
good luck
Aug 01, 2008 | Electronics - Others
Hope that helps xxx
Apr 02, 2008 | Dishwashers
Dishwashers Logo
151 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
