Question about Samsung Televison & Video
My daughter has sprayed her Samsung 52 inch Plasma screen withan Aerosol Mr Sheen original cleaner/polish. The screen has gone a bit cloudy. I think it is just the cleaner which has dried cloudy.Not the screen damaged. Could you recommend a substance to clean this residue off the screen, obviously without damaging it. Thanks for any information you are able to give. Norman Britcher
SOURCE: Samsung 50" plasma tv
search "black green" -- there are at least two solutions offered.
Posted on Dec 17, 2007
  • 2336 Answers
SOURCE: 42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Posted on Jul 15, 2009
SOURCE: Samsung 50 inch Plasma cracked
Same model 14 months old cracked panel from inside, bought 2 year warrant waiting to find out if they will replace it ?
Posted on Nov 12, 2009
  • 6 Answers
SOURCE: i have a 50 inch samsung plasma tv that i think
Upper/Lower Y Buffer defect
- Replace the corresponding upper/lower
buffers (E, F)
Posted on Feb 10, 2010
Testimonial: "many thanks really appreciate your input. how much should i expect to pay for the repair. cheers "
SOURCE: my samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Posted on Jun 26, 2010
How can i clean my plasma screen after it has been sprayed with a polish
If its a plasma screen you shouldn't be worried turn it off let it cool
and use a mild alcohol cleaner sprayed in a soft towel
Clean with it with jently passes until the polish is gone let it for a few minutes to dry out before you use your tv set Again
Hope I was helpful
(the reason you should not be worried is that plasmas have glass exterior filter that protect the inner plasma panel )
Aug 03, 2014 | LG Televison & Video
My mate cleaned my sony bravia 3d tv screen with ' Mr Sheen ' spray and now the screen seams to always have oily splotches no mater how many times i clean it, the picture seams not the same
It ate some of your coating off of the panel. Sorry, your stuck with it.
Never use cleaners on your flat screen. Luke warm water and a lent free rag is the way to go.
Jun 22, 2012 | Sony BRAVIA Televison & Video
Is there a way for me to clean my cloudy headlight covers or should they be replaced on my 2002 pt cruiser??
There are products available at your auto parts store that are designed to polish your headlights back to the original sheen.
Jun 06, 2012 | 2008 Chrysler Pt Cruiser
Windows will not roll up or down unless it rains in them
Common problem with windows sticking. The rain is working as a lubricant.
By far the best solution for this is to roll the window down (Help by pushing them by hand gently if you have to) and then spray a silicone based househould polish into the guides that the windows run up and down in. DO NOT use a wax polish, it will work at first, but then get sticky and gum things up. If the product is familiar to you, I find "Mr Sheen" (The one WITHOUT WAX in it). is an excellent thing to use.
Jul 08, 2011 | 2006 Mazda 6
RIGHT WINDOW WILL NOT CLOSE ALL THE WAY BUT MOTOR WORKS.
Sounds as if the motor is sensing overload as the units are designed not to trap fingers or heads to hard !! take the window right down then spray the side guides with a silicon based cleaner polish (mister sheen) then then work the window up and down repeating the polish - this may help, if not it is open the door trim time to have a look at what is going on inside, I have posted a detail of how to remove trim later in this s type section.
Hope this helps - good luck !
May 22, 2011 | 2000 Jaguar S-Type
My screen on my 52'' tv cracked can i replace it
My daughter cracked ours when it was 3 days old, like a lovely spider web, on the right side about an inch and half in diameter (she threw a brush). I used clear nail polish. If you have a big crack though, dont think that would be of any help.
Feb 05, 2010 | RCA HD52W59 HDTV Projection Television
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Daughter sprayed water on samsung lcd 32 inch on the front panel
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
Feb 15, 2009 | Samsung LTN468W 46 in. LCD Television
Wrong Chemical Cleaner on 60 inch DLP TV
Hi There,
Unfortunately, I think you may be out of luck. If you spray a screen directly you are taking a chance at killing your TV. You're actually pretty lucky that it still works. Some chemicals can eat right through or seep through edges and corners and ruin the life of your TV. I am not sure if Mr Clean contains alcohol, but that is the last thing you want on any screen. I would suggest trying to clean it off with an alcohol free solution for HDTV screens only or calling Mitsubishi immediately and see what they have to say.. Here is a similar product for what I am talking about:
http://www.meijer.com/WireLogic_CleanScreen_690020200.pro
Good Luck and Happy Holidays..
Dec 23, 2008 | Mitsubishi Televison & Video
NP 6025 printing Crooked
yes ther is ! first clean the glass with Mr Sheen(which is a spray on furniture polish) the glass needs to be slippery so the paper slides nice and easy over it.Then if that doesnt help,where the feeder attaches to the machine are 2 hinges one of which you should be able to adjust. Hope this helps.
Aug 19, 2007 | Canon NP 6551 Black and White Copier
Televison & Video Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
