I have an Accele RS623R Remote Car Starter that I received as a gift a few years ago. The gift included intallation but the Company that the unit was purchased from went out of business shortly afterwards. Where can I find Installation and Operation Instructions for this Unit as they were taken from the box buy the Dealer for Installation. Thanks, TD
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
  • 11 Answers
SOURCE: Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Posted on Sep 23, 2007
SOURCE: IR receiver on unit not working?
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
Posted on Jan 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Looking for Installation Instructions for microwave.
You can download them here:
http://ftp.electrolux-na.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Springfield&PDFtype=Install&PDFfile=316137234.pdf&model=PLMVZ169GCA
And you can find the owner's manual and other documents here:
http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLMVZ169GC&User=&Search=Search
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
SOURCE: Marantz Remote control model RC-18SR
Does the SOURCE ON\OFF button still work? If so, you can still use the remote to turn the receiver on and off by first pressing the AMP button (so that the remote window says AMP) and then pressing the SOURCE ON\OFF button.
Posted on Mar 12, 2008
I have a 2003 Pontiac Grand Prix, I had a remote starter installed a few years ago. it has always worked fine until this year. now it starts the car just fine but the car does not stay running. it stalls...
Maybe it's the anti-theft system an not the remote start . Is the SECURITY light lit on the instrument cluster ? GM anti-theft systems will disable the fuel injectors if there is a problem .
Apr 14, 2017 | Pontiac Grand Prix Cars & Trucks
My remote car starter won't start the car when I press the remote button. The red light flickers on the remote, but the car won't start. I don't know the brand it is because it was a gift three years...
There may be several reasons that the remote starter fails to initiate. Here are a few things to check:
1. You may have a shut off switch, usually located under the dash. It would be a small toggle switch under the driver's side of the dash, or in the driver's kick panel (where your left foot would rest when driving). It may be labeled on/off. This is one of the more common issues with the remote starter failing to initiate.
2. There may be a hood shutdown pin that is no longer making contact with the hood. Look around the edges of the engine compartment (the metal portions) for a metal push pin or, a black plastic tipped metal push pin. Push the pin in and remote start the vehicle. If the vehicle starts, adjust pin upwards to make contact with hood when it closed. This is another common problem. Lube Techs lean on, bend and break these pins when working under the hood.
3. Make sure that the remote is still programmed to the system. Press other buttons on the remote to see if the parking lights flash during lock and unlock commands.
Nov 04, 2010 | Vehicle Parts & Accessories
Car won't start, makes clicking sound
If you have a bulldog remote start, you should have it removed right away. I work at best buy, and we will not install these any more because of the problems they cause. You should buy something made by DEI, they cost a little more, but are very well made and come with a lifetime warrenty.
Aug 17, 2009 | Remote Starter with Keyless Entry
I rec'd a Hampton Bay fan as a house warming gift 2 years ago and a certified electrician has indicated the motor has gone out. How can I get this replaced. I understand there is a Lifetime warranty on the...
Contact the manufacturer and let them know what happened. The company will probably honor the warranty, especially if you tell them that you don't have the receipt since the unit was installed two years ago. I wouldn't tell them that you recieved it as a gift, just that you installed it two years ago and the unit isn't running.
Aug 04, 2009 | Dryers
Err 2 message
The ERR 2 code indicates there is a problem with the internal computer, specifically pertaining to the warming plate. I would advise you to call Kitchenaid Customer Service to see what options are available. They do not offer repair on the units, as it is not cost effective for the company or the consumer to have it repaired.
Their toll-free phone number is 1-800-541-6390.
Jul 01, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Started the car with remote. it ran for a few minutes and then shut down. now nothing seems to work cant start or drive with key
disconnect wires from unit then check all fuses. get car to start with key. then let me nkow year/make/model of car and what bulldog unit you have
Dec 07, 2008 | Remote Starter with Keyless Entry
Remote control
ok, i just threw my unit out, but i still have the remote which worked fine. free to a good home! just pay shipping. contact me at: justjim1220@yahoo.com. first come, first serve!
Nov 18, 2007 | Cyberhome CH-DVD 300 DVD Player
116 people viewed this question
 Grubhead
Grubhead
