Question about Shop Vac 401-12-00 Wet/Dry Vacuum
Bought a shop vac about 3-4 mos ago and while i was using it, it cut off and wont cut back on. This is the second shop vac that done this and I took the first one back and got this one and it did the same thing. It is a 12 gal. 4.5 peak hp.
Pyrhyc
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
  • 744 Answers
SOURCE: Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
Posted on May 16, 2009
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
SOURCE: I need a manual for a Rigid 5 gal shop vac or a
open it up. the manual is inside.
Posted on Mar 06, 2010
pappapumpdaf
  • 635 Answers
SOURCE: genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Posted on Mar 11, 2010
Testimonial: "I have a lot of upright vac bags from long gone vacs & I hadn't thought about cutting one down! Good idea, now I've just got to go get a foam filter."
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Every time I use my New Hoover steam vac it leaks all the time I've tried every thing, I even bought a new tank same problem, I'm not taking it to be repaired its the 3rd one thats done it an
After the second time I would have asked for a refund. Maybe you need to do some diagnostic work.
1. Does it leak while sitting unplugged?
2. Does it leak while plugged in but not being operated?
3 Does it leak when the solution is above or below a certain level.
4. Are you over filling it?
5. Does it leak only when you pull the trigger? (valve problem)
Keep asking yourself questions to discover where and why it's leaking.
Good luck.
Nov 13, 2012 | Hoover Max Extract Steam Cleaner
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Power
I had a similar problem with a Shop Vac. The solution was to disassemble the power switch and polish the metal electrical contacts to remove any oxidation caused from humidity. Tedious and time consuming but effective.
Dec 13, 2007 | Craftsman 17026 Wet/Dry Vacuum
Shop Vac 401-12-00 Wet/Dry Vacuum Logo
21 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
