Question about HP PSC 2355 All-In-One InkJet Printer
Printer keeps flashing print cartiagein right not supported..alos comes up on screen stating cartiage on right side is not intended for this printer. I have been using this cart. for awhile now it is the correct one. somehoe i got it working a few days ago , long enough to scan something and the black ink printed fine..then back to this info again it isnot working. I have taken out the cart. many times and still has not helped. HP 94 IS THE CART I AM USING.
  • 823 Answers
There is a problem with the computer sensor in the ink cartridge. That is what is causing this error that you are seeing. Is it a refilled cartridge or did you buy it new from the store? If you bought it new and it is doing this, then take it back to the store and tell them it is a defective cartridge and you want to exchange it for a new one. If it is a refilled cartridge and you bought it from an ink store, take it back to them and tell them that the sensor is failing. They will replace or repair the sensor and then the cartridge should work properly.
Hope this helps?
Posted on Nov 08, 2010
How to avoid the worse cartidges
Check printer cartridge compatibility before unpacking a new print cartridge. Make sure that it is compatible with your printer.
If it is not compatible then it can give error ...........
If you need any kind of technical assistance on printer support then call at-http://www.vtechsquad.com
Aug 30, 2012 | Canon MP270 All-In-One InkJet Printer
Cartiage is over and purchased another cartiage and puted into the printer but when we on the printer print is not coming is the problem
Hello Mondol,
There may the seal at cartridge, beacuse of that its not printing.
Please remove or pull the seal and then reinsert the cartridge and print the pages.
May 25, 2011 | Brother HL-2040 Laser Printer
I have a hp officejet j4580 the printer states there is a paper jam which I have cleared but i notice where the ink cartiage goes that area is stuck to the right side and won't go back to the left side to...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 25, 2010 | HP Officejet 5610 All-In-One InkJet...
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
I am out of ink for blue and yellow and just want to print in black (i have plenty of black) can i keep printing. It keeps prompting me before i can resume to replace empty ink cartiages. I really need to...
Perhaps... when you click "print", and the Print Dialogue box appears, try checking the box "Print in Grayscale". It may work, it may not (it's your printer itself that is stopping the process, not windows).
If it's not the standard Word/Excel type program, you can also trying "printing to file" through something like "PDF-Adobe PostScript Printer", which will "print" to a PDF... transfer to disk/flash drive, and head off to kinkos!
Hope it helps!
Sep 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HAving trouble printing
Check and make sure you did buy the right one first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
In pop up window it tells me colour cartridge error remove and check which i have done to no avail. also on comp screen tells me cart error. Have tried to press set up nothing happens. Also have a red...
Make sure the cartiages are sitting tightly in the printer and isn't loose. There are contacts on the cartiages and if the contacts aren't touching the ones properly in the printer it will show that cartiages aren't there.
Aug 21, 2008 | HP Office Equipment & Supplies
HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
Jan 23, 2008 | HP LaserJet 1022 Printer
Paper jam
i have an hp office jet 5510 and its not print and it keep on saying cartiage is jam , the timeing is all mess up the leg that bring the paper out keep on coming up whilethe cartiage is going across is there a way of reset the print to get back the timeing
Nov 01, 2007 | HP Officejet 5510 All-In-One Thermal...
HP PSC 2355 All-In-One InkJet Printer Logo
88 people viewed this question
Clive
Clive
